jlwelding
Everything posted by jlwelding
  1. WTH
    jlwelding posted a topic in General Conversations
    Damn brother I had no idea, cant believe Ive been gone so long. I'll call you soon.
  2. So I bought a 2012 4x4 1500 with 104k on the clock. Auto trans with electric switch on the dash. Course I looked up the oil and it says to use ATF Here in Tx it gets real hot so I don't think its good to run ATF, what do y'all run?
  3. If y'all would like to watch the entire rebuild of this Dana 80, my builder just got it edited and you can watch it on Facebook or YouTube. Just search Stratemann Automotive. Bring some popcorn you gonna need it.
  4. 20 years ago or how ever long ago, long time. I started running 2 stroke oil after reading Michael's research and never looked back. I keep hearing this Archoil lubricant and wanted to see if there was any talk about it. I cant seem to find the write up on it from years ago. So Im here picking brains on the subject. What do y'all know?
  5. 2k at 60 , egt's dropped 200 degrees. I was 800 degrees at 60-65. Now 600 - 625. I pulled 21k loaded with hay and it didn't faze it a bit. The hottest egt's got was a little over 1k, course the turbo helped a lot.
  6. LT235-85-R16 235-85-R16
  7. Finally got it done, the most awesome thing Ive done to this truck. Say good bye to high egt's and hello to fuel mileage and power. She's a power house now.
  8. Awesome, do what the Doc says and you will be up and getting around in no time.
  9. It wont connect for some reason. I shut the truck off and it bypassed turbo cool down and wont reconnect. I can connect to my OBD link scan tool but not the Quadzilla. Checked my hot wire, grounds are good, fuse is good.
  10. I been dragging my feet, I should have posted this a month ago. But the main thing is it's finally running right once again. Here it is and Im guilty of doing this a lot, looking over things and saying its good to go, its fine. Well I took my truck to two brothers in San Antonio who Ive heard really good feed back on. Anyway they found it in pretty quick. One of the pins backed out on the apps plug. And of course when you pulled it apart it would go back into its correct spot, push it back together and it was just making enough contact to run and once it got hot it would act up doing some wild crazy stuff. Just glad it wasn't the ecm. Check the obvious. I tryed to delete post, wont delete.
  11. I agree on the cooler giving a false reading no doubt. But I bought a Super Stick Transmission dipstick where they use the fass cooler for the dip stick access. You can actually add fluid if needed. Its a slow process but if you run your trans over full like most do it can save time. The shield on my truck is the same as the photo of Michael's I made mine outta piece of polished aluminum diamond plate and two muffler clamps.
  12. I have to say Diesel Auto Power really stepped up when I was having all that trouble thinking it was vp. I sent it back to them twice and they tested with out a question. Gave me a lot of help.
  13. I been dragging my feet, I should have posted this a month ago. But the main thing is it's finally running right once again. Here it is and Im guilty of doing this a lot, looking over things and saying its good to go, its fine. Well I took my truck to two brothers in San Antonio who Ive heard really good feed back on. Anyway they found it in pretty quick. One of the pins backed out on the apps plug. And of course when you pulled it apart it would go back into its correct spot, push it back together and it was just making enough contact to run and once it got hot it would act up doing some wild crazy stuff. Just glad it wasn't the ecm. Check the obvious.
  14. I didnt have my phone on when it did the idle thing so I dont know.
  15. I think I have the same OBD2 ive mostly retrieved codes, I'll check on that. And yes the throttle percent, when its acting up I can brace my foot against the firewall and get a good steady and you can watch it climb up and down on its own by as much as 7 to 10 percent. But I can set the cruise control and it is good.
  16. Sorry about that, yeah already done. I follow ya, it should just make it even more bullet proof.
  17. Is there anything in the WT mod that would have any effect?
  18. A month ago I started having surging and idling problems. I checked all the usual, fuel filters, pressure and everything in check. At hwy speed you can feel it surging in fact at all speeds of course at over 2500 rpm not so much. If you set the cruise control it goes away. I can watch my throttle on my adrenaline and its fluctuating up and down when using accelerator. At idle at a stop it will go as low as 500 rpm and Ive watched it climb as high as 1800 rpm. The apps was about a year old so I thought that had to be it.Put a new one in and roll along here for a bout 100 plus miles and the new apps starts doing the same thing again. No codes except the grid heaters which ive disconnected. If I turn off my addrenaline on my phone is that good enough or do I need to disconnect under the hood to test if thats the problem? With out codes its a crap shoot. I talked to Dap just because all my parts, fueling is from them. Airing it out with them we both are leaning towards ECM or connection. Timbo has not gotten back to me after leaving a message. What is the name of the guy in Florida who works on ecm's?
  19. Several years ago you told me about using motor oil on terminals and I was like man I dont know. I had to try it and so I put it on one of my tractors that had the white crap that kept coming back and it works no doubt, thats been over a year ago and hadnt touched it sense. Now when you said glass and plastic now it made sense.
  20. Yeah man that was back in 2008 when I thought I was still superman smoking 2 1/2 packs a day.
  21. Brother you keep doing what you do. Granite I was a little thrown off when we talked about it a while back, but I saw the fun you had with it too. And who am I to judge what you or anyone does. All I know is you have been a tremendous help to people everywhere fixing their damn trucks. Even me back in the day with the miss from hell. You have always been a phone call away. And thats what I told you yesterday, I'll be calling just to see how you are and a ear if you need it. I found this place when I was laying in the hospital with two back to back strokes, didnt think I was going to make it. This site gave me something to do, and little by little people began having intrest in me and talking. Thats all we need sometimes is mindless BS sessions. Rock on brother, later.
  22. So it never caught my eye before but Its bent. Either someone before me backed into something or jacked it up by the sway bar. Its got to be replaced so go back with stock or is there something better?
  23. Ok fellas it took me a day or so to get around to putting NAPA fan clutch in and its a win. I cant believe how much of a load was on that eng turning a locked up fan. It even shifts smooth again it really is amazing how you can get used to something and not realize it. That was two Hayden fan clutches totally locked up.
