Silverdodge
Everything posted by Silverdodge
  1. I would really like to try a modded 4th gen intake and plate but don't know of it would bolt up
  2. Sorry I spaced out on the taking pics I installed the intake form which is a black plastic CFM plus that I ended up buying for 50 bucks it works at cooled egts and certain ranges by about a hundred degrees the aluminum crazy Carl's intake is not on the truck I can get pictures of that on Monday when I get to work I got to get that set up on the CMM so I can make a blueprint for certain millwork I ended up buying an hx35 the CFM plus intake and the crazy carls tunnel ram for about $200 for everything so I might as well put it on the truck
  3. So I got offered a billet intake from crazy carls tunnel ram pic down below for 100 and a intake horn aftermarket for 100 as has anyone ran one of those tunnel Rams any feedback and what is the bolt size for the intake plate m10 m8 1.5 1.75?
  4. last year around this time I resealed the tappet cover and the vacuum pump the tappet cover seal was cracked and had about a 1/8 in gaps I was leaking about a gallon a week
  5. Would u think I would have issues with it
  6. I can actually get those for about 12 dollars
  7. Actually I'm thinking about switching to this filter after reading that thread BD7317
  8. Look on Amazon u can buy them cheap
  9. I ran one of them systems before on my old truck from amsoil nice pretty kit until issues mine on the filter base split so ya 3 gal of oil on the highway never again threw it in the trash in my area I wouldn't recommend it the filter close to the engine is better summer it's 90 winter last year negative 40
  10. like I said I just started running an s&b style filter with a filter box and it's been fine
  11. Ya when I put my s300 on I started noticing deforming of the filter media that was clean I took it off and have been running s&b
  12. Sounds to me like there's something wrong with the fuel boss itself
  13. I want 45 PSI almost pulled one of them in so no go here
  14. Interesting oil and fuel filter brands seem to be less cut and dry then say s&b or afe air filters
  15. Same with the to each there own previous owner of my truck installed a draw straw and did it wrong so had quarter tank issues so I said I'm done sumped it fixed everything
  16. Any reason on Donaldson over the fleetguard And coincidentally I run Donaldson and Baldwin filter setup and normally buy all my filters through Amazon
  17. I'm curious what you guys end up running for oil and filter personally I run amsoil 5-40 and amsoil filter now I'm changing to fleet guard filter LF16035
  18. And that's why I put my sump on people disagree with me that's fine but if one of the g&r or beans sumps get caught on something that would rip it out it would pen penetrate the tank anyways I've had sump for a year and 0 leaks but I damn sure have fuel to my airdog all the time
  19. Buy the matching egt hot having matching guages makes my OCD weird
  20. I actually left the amps in place zip tied them to the doors and bolted new speakers in
  21. I have an 01 with the factory infinity sound system and I want to put aftermarket speakers in it so does anyone have what color wires to cut splice ect
