Silverdodge
Everything posted by Silverdodge
  1. I haven't noticed my d80 being wider then a d70
  2. No she will pull 30s on hills towing and never lacks power my turbo choice right now is what's limiting me
  3. Well I hit over 50 sustained
  4. To proceed u need to figure out what size turbo u actually have 60 what and I have what is in my signature and can build 30 plus psi at 2k
  5. Front springs on the diesel will be stiffer than the gas the d80 is different from the d70 I'm confused as to what I want to know last year I swapped 3500 rear end and springs in to my 2500 the only real difference Cummins 2500 to 3500 in the same configuration diesel short bed single wheel is rear end Soo what do u want to know
  6. 9 time out of 10 I'm running 70 to 75 but I don't deal with mountain travel
  7. I run 140 to 150 down the road transmission wise
  8. A solid 18 miles to the gallon here and usually 800 to 1000 egt 150 trans
  9. Yes final gear ratios and are annoying at 3.21 but I finally got it all figured out lol so i can live with it
  10. Same size as was on my truck when I bought it front has a quality leveling kit will pucks new 4 links and had a rare parts track bar
  11. Hell I went threw 2 rear ends in 2 months my other half was not happy about that one and also maintenance wise never ever ever ever buy the cheapest of anything
  12. Personally I run 35 12.5 17s with a -12 off set and like that look and also my best advice to u is not to do anything drastic like go huge injectors ect and also keep up on the maintenance and there good reliable trucks but remember when it goes down it will be expensive ?
  13. what really sucks is when you have iquad and all your tunes are on a single phone the battery ends up giving up the ghost and smoking out of the power connector while you're driving down the road and u loose the tune and everything arrrge annoyed
  14. Has to do with grain structure
  15. If I remember right from metallurgy u are correct
  16. They make kits to put it on the inbound side of the horn
  17. Mike I'm a machinist I can make the horn fit if the bed plate fits but but I would have to get custom bent lines or some other odd thing And at that point making a bed plate on a cnc would be childs play
  18. No that's silly but something like this probably would
