Evan
  1. Transmission will produce the least amount of heat with the convertor locked and functioning correctly is i think what he was trying to say. Even working correctly in 1 2 3 tourge converter unlocked driving on fluid coupling the transmission will produce more heaat. But healthy shoukd have no issues staying under 165ish Pulling hard in 2nd id let it hit 180 collant temp if it sustains there id keep trucking. If it walks passed id shut her down. The heat exchanger should sustain it dumping transmission heat. If it cant dont keep driving. Trans temp might be more important than fuel or exhaust temp 3rd locked is the best place to be towing will produce the least heat. suspensionsn is tourqe convertor is actually locked when trucks in 4th. Was this issue ever figured out?
  2. Your oil is brown youve neglected your transmission. Theres nothing wrong with 305 tires Service the tranny to include band adjustment. Probly should put a new tc solenoid and tranducer in it while your in there. The auto transmission seems to be the most neglected machine in the world dont be like that lol. Id cry if my red transmission fluid was brown heck im about to cry because yours is
  3. I did Larry's parts got 8 years onnit after. Then i got 2 years on a cheap autozone unit Now on a autozone duralast gold hoping it goes for more than 2 years Making goid use of lifetime warranty now
  4. Wouldnt you pull relay and run a jumper in its place. Ive never quute understood relay. U currently run a jumper no relay and no toggle switch to lick converter. My truck functions as a normal oem truck minus the relay. I used to pkay with a converter lock switch but have found for my use the converter swutch isnt needed. I lock 3rd comming off hills without switch. I do think the toggle switch coukd be used to test but i feel id go in and put a new converter solenoid and all under pan eletronics in because of to many un knowns. The connector that goes through the case next to tv cable is known for being problematic. If you unplug that connector and its soaked in fluid its no good. Im currently running the kde manifold and gm solenoid the borge solenoid on oem manifold is suposed to maybe be better. Ive had two borges on this truck and am on my 2nd gm. Havent had gm solenoid fail yet. Put all new eltronics in when i refreshed the trans. If unknown on eltronics id recomend all new harness solenoid, tranducer and plug through the case. Its a coyple hundred bucks will eliminate a few possible issues right of the bat. The battery cables(all) and grid heater cables can all affect tourge converter lock and 3 -4 shifts. Also curious if its locking convertor in 4th or not
  5. Ive had no issues with the ppe deep pan. Though im unsure anything more than welding a drain plug in the eom pan is all thats needed.
  6. I do tape measure aligment had just as good if not better results than alignment shop. Been 12ish years since my 02s been on a rack it has the truest wearing tires around. My jeep is freaking pretty sweet to. But its all gutted and reworked from axle tubes to the frame. Nothing stock left. Ive never had it on a rack. Tires wear true and you can drive it 80 with your pinky while shes screaming 3500rpms. So no i wont be putting the truck on rack after fabbing trackbar. However if something does change and i start getting bad wear or funky handling characteristics i will suck it up and get help. Though unlikely I did do 2" leveling on my truck but i have 1ton rear springs. The 04 is pretty sacked out with fuel tank and junk on on it. Might make more sense to lower front and inch or two or maybe raise rear to handle load better. But its kinda ok its sitting about level as is its a work truck. I do the track bar because the oem bushings are junk. Its silly to fabb a fixed bar. I see now why you mention leveling kit. My 02 has about 200k on my track bar the 07 that got totaled had about 100k. We were lucky to get 20k on the 07 oem or after market track bars. That was a cab n chassis truck so maybe its thrust angle was off from the factory eating the track bars since the front end was same as 3/4 Lol i dunno even know what thrust angle is track bar locates axle side to side preferbly centerd on frame at ride height. Then control arms do castor. Thrust angle is probly a fast food aligment shop term made to make themselves sound smart.
  7. Ill tell you something. If its not leaking youve got real problems something is very wrong. Would advice truck is parked for further evaluation. Ive had my valve cover off 5 or 6 times in 14 years ive had my truck. Its probably about the only place its not currently leaking. I also find sometimes removing more stuff out your way turns into far less work than working around n through crap. Welcome to the hen house or is it the **** show. Idk
  8. Thats a good looking truck. For what its worth our 04 has 219 k. Im working through the front end. 08.5 steering oe balljoints are shot. Unit bearings toast. This is a small tire street rig. I do beleive big tires will cause parts to wear faster but this ones eating parts at about the same rate as my 02 did with big tires. Havent done the track bar yet as it seems to be alright. When its time itl get a adjustable track same as my 02. We dont even tow much with the pickups anymore just not worth the wear and tear. Ohhh this clutch is headed out aswell im waiting for the transmission to break so i can go through it and install new clutch at same time. You know 2 birds one stone kinda thing. Offcourse it rains when i start a project
  9. Dude get off the small tire ball joint crap, I get it yours is better. Thank you it feels good to do it. Ill probly have to go now since theres no point in being here i have big tires you know
  10. Bringing my transmission cruise control talk over here. Also a few videos from durring transmission work. The ford i picked up for cheap. Pretty much just so i could have wheels it also showed me how much these dodges suck. Ive now givin the ford to my daughter The 3rd gens our work truck
  11. Lol idk do ot right i get it wrong do it wrong i get it right. Ive had tge valve body out a few times without removing neutral switch. One time on the bench where its easy it goes wonky.
  12. Its been messed up since i installed valve body on the bench. Maybe partly because i had sensor removed when installing valve body. Being on the bench made it to easy to get it wrong i guess Plastic bits were still intact on rooster comb
  13. Got to thinking about neutral safety switch. I rememberd truck used to start in drive. It now currently will start in reverse, and second gear. Wont start in drive or first. Tomorrow im going to unplug safety switch jump the prongs and see if cruise control then works with the switch bypassed
  14. Will check out the vacumn lines and check if back up likes work. I thi k back up bulbs blew 10 years ago or atleast 1 lol. I have fixed one vacumn line by the battery quute a few years ago. Maybe it rebroke
  15. Yes very good. Great work Question for you. Just did my 47refresh no issues on assembly transmission full refresh, seals, bushings, steels fibers, all eletronicals. I did have issues with nuetral safety switch but resolved that now i have ni cruise control. Indicator turns on on cluster but doesnt set. Speedometer does work everything works but cruise control. Cruise control did work before pulling transmission out of truck. I realy like cruise control kinda at a loss. Only issue was nuetral safety switch so my mind keeps going back to it. On first start up i jumped the plug with a paper clip then figured out i wasn't making contact on switch to switch lever inside pan. Thanks for your response.
