gipperkid
Everything posted by gipperkid
  1. Thanks. I figured there were others that had the same dilemma.
  2. Ok, so like this. Using 100% of a 7x.010 to get that 500hp, or using (just guessing here) 70% of a 7x.012 to still get the same 500hp, but have more room to grow.
  3. Lol, Yes clear as mud. I will eventually gain knowledge about the quad. With your guidance! Lol. I understand about matching injectors with turbos.
  4. So I recently acquired a Quad with V2. However I just finished installing an EGT probe for my Isspro gauge prior to getting the quad. I'd like to run pillar gauges since I have had them on the shelf. But also want the gauge to work with the quad. Can I install another probe either above the current one? Or install the second probe in the front half of the manifold?
  5. I see. So injector size in a sense, with the quad, does not matter because the quad can control the fuel.
  6. Oh and the question if larger injectors are meant more for revving out to the higher rpm ranger? Meaning if I don't rev past 2400 is there reason to go larger than a 150.
  7. Are larger injectors meant mainly for the power band in higher rpms (2400-3200)? SAC or VCO? Or is that based on the intended use of the truck.
  8. Are larger injectors meant mainly for the power band in higher rpms (2400-3200)?
  9. Jealous. Let us know how is does.
  10. I guess I need to decide if I can bring myself to spend more. I initially made mind my up I was only going to do 50's and the EZ.
  11. I'll see if I can find a buyer for the 50's......and Edge EZ.........
  12. Well the injectors have been on the shelf for over a year. Too many irons in the fire all the time. With my truck down needing a VP44, I was going to do injectors and adjust the valves. So I figure since the valve cover will be off, instead of doing injectors twice, just sell the 50's and go bigger.
  13. Well here's a question. I haven't installed the 50 HP injectors yet. Would it be fine to go step up to a larger injector with the HX turbo and use the V2 to limit fueling? Then when funds allow the trans and turbo to get upgraded, adjust the tune accordingly.
  14. Would the V2 be beneficial on a basically stock truck, leaving it untapped? Yes my trans is stock. Within the next year I'll be paying FirePunk a visit. But until then, I just have the HX35 swap, 50 hp injectors, and Edge EZ.
  15. I work at a dismantling/salvage yard. We sell computers to FlagShipOne on a daily basis. Also we sell a lot to another place called All Computer Resources in Miami, FL.
  16. Thanks for the advice. I just hit up good old Amazon and found a brass one.
  17. Just a quick question. Finally getting my gauges in. Going to get my boost reading from the block plug behind the filter housing. My local hardware has the 3/4 to 1/8 bushing but only in galvanized. Wanted to make sure that was okay or if I needed to get a steel fitting.
