gipperkid
Everything posted by gipperkid
  1. Got ya. Definitely something not for a novice like me. Lol!
  2. @Me78569 Ok, actually will be getting 7x.012. I mean there are probably a handful of parameters that effect that anyway.
  3. I have always thought about putting the stock filter housing back in play. I'm like everyone else. fuel line straight from FASS to the VP44. Only need the big line kit to put the stock housing back in use?
  4. @GSP7 Local body shop in town. Yes that is the spray booth. He is my go-to paint guy.
  5. I hide my green under the hood and in the fuel tank.
  6. Not running my Quad yet.....but glad I'm on the band wagon....
  7. 2002 2500 is Patriot Blue Metallic. In the process of being two-toned. Dark gray on top, Blue on the bottom. 2000 1500 Sport is Forest Green Pearl. Don't mind the silver bed. Had some minor over the passenger wheel and hated looking at it. I had this rust free bed stashed back for 5 years. Lol! And Painted....
  8. @Mopar1973Man Does the Mopar1973Man.Com High Idle Kit work with factory 3 cyl high idle and Quadzilla high idle?
  9. @crf450ish I wish I did. No one around has a smarty I can borrow. And I'm definitely not paying the dealer. Need to buy a new pyro for the quad also.
  10. Lol. It's a bad picture to show the color. It was dusk. The jambs are already the factory color. This was total and I had to have the truck painted after putting it back together anyway. Just the first guy that did it used cheap paint and clear. I just didn't know if the gray should be top color. I am going to have him do some spray out cards to decide. Also I don't have my leveling kit installed. Have 2" spacers on the shelf. Here are before pictures of this same truck:
  11. I can't remember, but are resistors directional? It's been a while seen high school physics. LOL.
  12. Going to two tone my truck. Current color is Patriot Blue. Had it painted a couple years ago, but it's one of those you get what you pay for deal. The guy that did it used cheaper quality materials and it shows. I'm keeping the Patriot Blue so I don't need to mess with the jams and such, but adding Dark spiral gray metallic (GMC color 805K). I thought put the gray on the bottom, but my new paint guy suggests the gray on top.
  13. @nukethenazis I'd like to know more. I would guess by using a relay?
  14. Turn indicators and running lights both? Or one or the other?
  15. Trust me. You are going to want more. It all started with an Edge EZ...........Lol.
  16. Yea I'm just going to run the wire to lights-on power source.
  17. Well that's what I figured. Thought I'd ask though.
  18. Yea, my 01 1500 does too. But I was looking for a "lighted" power source, that comes on with the running lights, within the door.
  19. Changing my manual mirrors to power, heated, and lighted. I know doors are pre-wired for the power/heated and I've already added the mirror control swtich and the temp control with heated button. My question is if anyone knows if there is lights-on power source inside the door. Looking to avoid running wires through the dash to the light switch.
  20. Thank you. I am actually reading the article now.
  21. Ok, maybe a dumb question here. With any tune made or the custom tunes available on here, do the tunes have the power levels (i.e. 0-6)?
  22. I think there might be enough room to drill in the side.
  23. @AH64ID I like the idea of monitoring temps before and after. I just hate to take the turbo back off to drill the elbow. I could probable put a weld in bung on the down pipe. Yea. I drilled and tapped mine with the turbo off. Stepped up drill bits to the final size. Use Plenty of WD40 when cutting the threads. Use anti-seize on the probe adapter threads.
  24. @Red Rambler Get the tap kit from DAP if you don't have access to those tools. Isspro guages. Install guides: http://www.dieselmanor.com/diy/CMS-G2gauges/CMS-gen2gaugeinstall.asp There are plenty, just search the forums.
