gipperkid
Everything posted by gipperkid
  1. Opened the IQuad app and I got a message saying I needed to update to the current verison. I have 1.9.41 installed and that is the current version on the Play Store. But I found a download for 1.9.5.
  2. Figured as much. I was just curious. Regardless, I wasn't putting the injectors in my truck without them being gone thru first.
  3. Had DAP rebuild some injectors with 150 nozzles. I got the injectors in a trade that were supposed to be 200's. The numbers on the nozzle are DSLA 150 P 755, and a 77103 with 939 below. It's not a big deal, I was just curious if these were actually 200s. The notes said all 6 old nozzles were leaking anyway.
  4. @Cummins4life Can't go wrong with DAP. Great company. Quad and 150s. Having a set injectors rebuilt with 150 nozzles by DAP right now.
  5. Ok, Turbo will eventually be upgraded.
  6. Oh definitely not with an edge ez. Sorry I should have clarified. I'm just planning ahead. I have the quad on the shelf loaded with v2 tuning.
  7. I did some trading with a friend and have his 7 x .011's. They are DAP injectors. Supposedly only have about 1500 miles on them. But I am sending them to Jacob for testing and rebuild to be on the safe side. But should I have 7 x .010 nozzles installed, or will the 7 x .011's be manageable for under 550 hp?
  8. Ok sounds good. Just didn't want invest time on installation if the clicking sound was not normal. Of course it could still have issues, but won't know until it's on the engine.
  9. Strapped for cash so I pulled a VP44 off a spare engine. It is a Magnum 24-4015. But when I spin the shaft it sounds like a ball bearing clicking. Kind of like a valve opening and closing when it hits each injector line port. It's been rebuilt at sometime because the pump is much cleaner than the engine is. Not sure if that is normal or if it shouldn't make any noises when spun over. Also would it be worth while to send it out to be bench tested.
  10. Uh oh. When did this problem show itself? I thought with the lower timing range things were safe.
  11. @Mopar1973Man Is this a cheaper alternative to the Nations Alternator?
  12. I have thought about the 62/68 but I thought there would be lag with a large single like that. Hence the new SX-E 57/65 or a 62/65.
  13. The 7 x .010's would be well suited with one the above mentioned turbos: https://www.dieselautopower.com/dap-screaming-eagle-sxe-fmw-2nd-gen-fit-57-65-14-t3-gated-hx40 https://www.dieselautopower.com/dap-screaming-eagle-sxe-fmw-2nd-gen-fit-57-65-12-t3-gated-hx40
  14. Realistically, I would say 400-450 hp. No more than 500 hp.
  15. Definitely would like the turbo to be quick spooling. With the Quad, would either of these turbos be suited OK with 7x.012s? And if going to a SXE 62/65 or 62/68 would the quick spooling be gone? Or these turbos getting into the higher horsepower range (500+)?
  16. @dieselautopower With the S200GX-E, is the 400hp at the crank or to the wheels. Turbo for around 450hp range?
  17. I know this subject has been covered before. But I have a quick question. My buddy has his 99 Dodge that has the infamous lockup issue. I told him over and over it was the alternator. I told him to test by unplugging the alternator and of course the issue cleared up. I said he needed to get a Nations Alternator but he bought an O'reilly's reman alternator. After about a week he has having the same issue. But now even with the alternator unplugged the trans is still surging in and out of lockup. Could the PCM be failing now?
  18. No, just black. None taken. Completely understandable. I just had a few stashed backed and decided to let go of one.
  19. Could have saved you half that cost. I have a bezel for sale in the classifieds.
  20. View Advert SOLD AutoMeter pyrometer gauge AutoMeter Pro Comp Ultra Lite Pyrometer Gauge $27 Shipped *Note: no egt probe Advertiser gipperkid Date 08/28/2018 Price $27.00 Category 2nd Generation Dodge Ram
  21. View Advert SOLD AutoMeter boost gauge AutoMeter Pro Comp Ultra Lite Mechanical Boost Gauge $27 shipped Advertiser gipperkid Date 08/28/2018 Price $27.00 Category 2nd Generation Dodge Ram
  22. View Advert SOLD 94-02 Clear Tail lights 94-02 Ram Clear Tail lights. Has LED Sylvania ZEVO brake light bulbs $55 shipped *Note: Driver light has some slight white overspray on bottom corner Advertiser gipperkid Date 08/28/2018 Price $55.00 Category 2nd Generation Dodge Ram
  23. View Advert SOLD 94-02 Smoked Headlights 94-02 Ram Smoked headlights $55 shipped *Note: single bulb headlights w/ dual bulb harness included Advertiser gipperkid Date 08/28/2018 Price $55.00 Category 2nd Generation Dodge Ram
  24. Yes! I am half tempted to ship you my trans and have you build me a stage 3 with billet output. But by the time I pay freight charges, a Firepunk Comp 1 is probably the same price. Oh, what to do.................. @Dynamic maybe PM a quote
  25. Well $4k would get me a tow type transmission with a single disc. But I'm going for the billet input, output, triple disc. Better to over build just in case. Power goal is 500-550hp
