gipperkid
Everything posted by gipperkid
  1. The bolt is seized on the clamp so I can't get the compressor cover off. I don't want to snap the bolt unless I plan on using the turbo. There is no play in the shaft but the compressor wheel has some chips on some of the blades. So I would rebuild it anyway. I measured the compressor wheel opening, just over 66mm, and the exhaust opening is just over 78mm.
  2. @Quadzilla Power is the current app the 1.9.40?
  3. Just measure the compressor wheel opening of the actual wheel?
  4. Got a turbo I need help identifying. Has SD-343579 etched on the charge pipe.
  5. Anyone have a Smarty I can borrow?
  6. I bought a used Edge EZ off a CumminsForum member a couple years ago. Works great, really woke the truck up. I am actually going to be selling it if you are interested. I think it's the best way to buy. I picked up a Quad off another member a few months ago.
  7. Long Bed. Forward most bed mount. Used draw straw 1 in factory module. All fuel line covered with convoluted tubing (wire loom) and zip tied to wiring harness that runs along the frame.
  8. Figured this would be the thread to ask. Wanting to get the quad installed. I have been running the Edge EZ on level 3 for the past year. Is the stock injector daily tune basically the same as an edge ez?
  9. I'm sure I could get my hands a couple good dash inner structures.
  10. Will you be adding your tune to the repository once finished?
  11. @Carbur8tr How does it feel power-wise?
  12. Central Ohio here.
  13. @Me78569 Hey quick question. Is there newer version of the IQuad app, or is the one on Google play current? I thought you had a made a newer download but I can't remember where I read that. Just updated to the new 2.7 software.
  14. I stand corrected. I have a 6-speed coming in.
  15. @Me78569 I agree with you on the towing aspect between an auto and manual. The gearing spread is just all wrong to tow well. A 5 speed auto would be great. Probably would never handle the power and abuse, but I think a CVT trans behind a Cummins would be neat. My wife's Mini Cooper has the CVT and it just winds out and goes.
  16. I know of an 01 4x4 with a 5 speed coming in to a yard local to me. I always thought about doing the swap, But I think a built automatic is what I prefer.
  17. So say I had the 2.7 flash, that gets replaced with a different flash or a 2.7 flash with the added line of code?
  18. Also where in the quad does this code get written? Or is it tune of some sort. Sorry if it is a dumbass question, still learning the V2.
  19. Have a video of the 5 psi launch?
  20. How does this work with torque management?
  21. How does it work? I guess the "science" behind it.
  22. Definitely sounds interesting.
  23. Terrible disease! Just wish was my trans was already done.
  24. @Carbur8tr Are you running any wiretap?
