OmahaGen2
Everything posted by OmahaGen2
  1. I know this is an old thread, but thought I would mention, I just seen where Banks is offering a 2nd, 3rd & 4th add on heat element available to add to your intake. Just FYI
  2. Well, I did get a new Quadzilla Adrenaline, I found a dealer who had it listed at a great price (I believe it was a lower price than what was allowed to be advertised) & they matched it. Of course I have purchased a few thousand from them over the years. (Looks like I will be making additional purchases be it I have two to maintain now. (you've been doing that for a while now, it's a lot at times) On another matter, since I repurchased my 1999 2500 back, I am changing out the the front suspension, thus far I have purchased Thuren Fabrication track bar & their XS front springs, Bilstein shocks to match the travel & Stryker off road control arms & RXR some of the bushings, etc. One thing I find interesting is if you ask 3 different fabricators how to install all this you'll get 3 different answers LOL. I'll try to do a write up/pics for some or all of it for the website if your interested. It would be my first write up so can't promise the level of quality, but I do promise a LOT more detail/info than what Stryker has on install. (see install video from their page) I thought it was way to casual be it they didn't say anything about how easily someone can get in trouble if they simply just start ripping control arms off. LMK if you would be interested in a write up & if so any tips would be appreciated.
  3. Was just reading your post from December, that was an expensive Jump start. Ouch. I just received my Quadzilla from DAP. Congrats on 500K miles. I thought I had a long to do list for my truck until I read your list.
  4. Do we get any kind of a discount buying through DAP? Specifically I am wanting to purchase (again from DAP) the quadzilla with iQuad. Thank you
  5. Be very mindful of your tire ratings, I've seen that sneak up on people a few times. I pulled our trip axle 5th wheel all over the country (with my 2013 dually) One thing that made ALL the difference in the world was a air ride hitch (https://hensleymfg.com/) They are a little spendy, but worth every penny. they save your truck, trailer & you smoothing out the road.
  6. And the hit's keep coming, sorry your going through all of it, but like you said the perk of being married.
  7. Well I came back to the site just in time then. Congratulations!
  8. I bought my 2013 with 118k miles & all welded up. I took it to the dealer for a all wheel alignment, when I got the written report back from the tech it stated, alignment within spec's, but would have adjusted it further had it not been welded. My complaint was the front tires cupping, "Viola" Ram responded by paying to replace the drag link. Pretty certain I am going to go with Thuren track bar & front coils (Thuren's Overland leveling system)
  9. Did you ever figure out how you got water in the system?
  10. I bought my 2013 with Cooper At3 & in spite of what I read about not the best stopping in wet conditions they performed fantastic on 4k mile trip pulling my 15K 5th wheel in a lot of rain, never had a problem one. They did well in the GA mud as well. The fronts cupped a little, but that wasn't the tire. I am getting ready to put Ironman AT's on next.
  11. OK, I thought I had this, but I have only to connections that go to my alternator (see pic) and the other end of this alternator lead goes into the large loom & then breaks out by the VP44 and up to the negative side of the PDC. I also have a power lead going from the drivers side battery to the PDC. I also have a ground going from the drivers battery to the fender & one from the drivers side to the frame. (I had already changed out the cables with a kit several months back) Never had a problem except for T/C lock unlock started happening..unhooked the power from the PDC 140 amp to test.......it eliminated the T/C problem.......changed the alternator out, put on a additional ground from the PCM to passenger battery. Worked for a while...and now I am opened up the loom seperated out the grounds & I am not sure about what to do with the PDC negative. I would think big awg ground, but why isn't my truck fried? again no other problems or codes..Ok I figured it out. It looks like a ground cable, but it is NOT..If I had kept reading which I did..I did run a extra ground battery to battery. And yes I triple checked where it runs to..
  12. As Always thank you (and everyone) for taking the time to document, taking pictures and sharing.. .I could not afford this truck without the information I have gained from this forum & that's a fact. So about this modification, I am not sure where I missed it, so just to clarify, the alternator lead going across the motor to the PDC is eliminated. In it's place we will have: A. Alternator charge lead from the alternator to passenger battery.. B. A power lead from the drivers side battery to the PDC. (The grounds I believe I have correct & will be done with all in about an hour) Electrical is my Achilles heel .......LOL I ON EDIT; once the B+ charge wire from the alternator is moved the shorter distance to the passenger battery, a great solution, but you lose temperature battery sensing with the sensor still on the drivers battery. You can either move the sensor over to the other battery, with some modification, or run more parallel cables battery to battery. It will need two more heavy cable negative to negative and one more heavy positive to positive. My solution is to run one longer B+ charging cable to the drivers side battery. Without the battery temperature sensing feature on an old battery that develops a shorted cell will cause the PCM to keep charging the battery at full tilt. The alternator will get smokin' hot and can cause damage. Luckily I got home before any real damage to the PCM or other possibility of a fire. I popped the hood , knowing something was wrong and the alternator was so hot it was smokin. You couldn't touch it. I replaced it and both batteries and all was fine. I did notice where the shrink tubing on the charge wire started to melt as well. I'm glad I caught it when I did. AN IMPORTANT UPDATE: A recent conversation with Billy (W-T) he spoke about the absolute importance of properly paralleling both batteries by adding one more positive to positive cable and two more negative to negative cables. This a much better solution than all other options so that the computer will be able to temperature sense what one bank of batteries need as one battery bank. Not having a situation of charging one battery while the other has the temperature sensor. IOW, they need to be properly paralleled as one battery. This very important factor has been eliminated from W-T's original write up, so I just wanted to bring this up.
  13. Exactly what I couldn't figure out..What about charge line to the PDC? And here is the answer, Thank you...not sure how I missed it before or if that was missing, but I was really starting to scratch my head.. Thanks to all that contributed to this..You guys are the best.
  14. Thank you for gathering up the different pics for the different angles, etc This is a real help as I am trying to get mine glued back together ..just can't see paying that $350-(partials replacement) to $800 price tag I would seriously look hard at a couple 2009-2015 dash mod's I've heard a little about before dropping $800
  15. I put LEDs in my license plate lights (as well brake lights) & they to help when backing up.
  16. Sorry for the long delay. Had to finish it up & slam it into the paint shop. Found a couple problems & fixed a few. #1 1688 was operator error, New VP plug (3 prong under pump) was NOT plugged in. 2. The harness they sent works fine if you hook it up correctly (I had the wrong instructions & that was "mostly" on Fass). 3. Return line regulator (Spring with checkball) was stuck. Ball became stuck in spring, etc & was spiking the fuel pressure. So since I corrected these issues: No more codes, return fuel starts immediately as it should (although I think the return line should be as big as the inlet side in ***) & with the "New & Improved" regulator they sent immediately, All is well again. I did install the 165 & correct me if I'm wrong, but with the proper return the only down side is it keeps polishing fuel. I updated & upgraded quite a bit at one time (more than I probably should have), but I was in already in there right? I did get the New VP44 (rebuild with new ALL) new Injectors, tubes, vac pump rebuild, water pump, belt, & tensioner, Bolied, tested the radiator (due to catch can tube) (WOW, Mine looked just like the pic's you have on here,) Remote catch can & line, Harmonic dampner, Front crank seal, new gauges fuel/pyro/boost in the pod, (removed 3 miles of dead wiring under dash, 1 was an actual phone landline) reworked wiring for gear vendor overdrive, wrapped all other wiring, detailed the motor a bit. & here she is running. I have yet to install Quadzilla & APPS although I have them. Btw, I could not have done all this without this forum. Thank you. New VP44.mp4
  17. I installed a Fass Fuel pump & water seperation system & in the instructions it simply says unplug the power for the stock lift pump. Well needless to say that equals codes & Fass tech support had 2 suggestions. 1. leave it uplugged & if the code bothers you some code readers will erase that code from the system. Umm no. 2. If you go to an auto parts store you can by a resistor, "I believe it's 5 ohm & plug the power line into that & it simply tricks the ECM into thinking that it is plugged in and working fine. (hmm sounds like a guess, guessing I can do on my own thx) So anybody have a better idea? I'm actually getting 3 codes & it almost started twice, but I refuse to do long cranks. I have fuel up to the injectors already I started with 1,3,5 lines being loose. P1693 JTEC detected companion?, P1688 Internal Inj. pump controller failure, P0238 (I think) transfer pump curcuit out of range. Going to finish reviewing all my installs check it again after clearing codes & trying to fire it again. Thank you all. ! P.S. The instructions on this Fass System leave a lot to be desired I mean WOW. Another time I will elaborate.
  18. Well done, great pics & obviously very easy to understand. So why not change out the banjo bolt for a easy 90 & a fuel rated hose back to the tank?
  19. The way this is written, I wish I would have started here first regarding fuel pressure & just how the overflow valve affects it as well. One item though, so what do you suggest for that 5 mile steep grade downhill? Sure you can play with the throttle a little, but?
  20. I was thinking along those same lines, but wanted to hear it from someone wiser than myself. On the rebuild side of all this..thank god. Work just keeps getting in the way. Appreciate the feedback.
  21. Here is my question regarding the timing cover (see pics) there is significant paint and/or powder coating on the inside of the cover where the seal is installed. Any advice on this? Remove the build up without changing the shape nor scratching or putting a grove into it? I noticed this on the timing gear cover in the video posted here as well, curious if it leaked. (Btw most pic's on this thread & the follow up thread will not open.) I appreciate any input on this. 75K is all I have on the clock & yes it was leaking. TY
  22. Right? I'm with crf450ish, simply done, kinda. Thx for posting changing mine out today. :0)
  23. Oh My, This very helpful, Thank you. I knew this was going to be work, good thing I enjoy working on & with my truck. (most of it) Anything I need to do to remove the smarty tuner? So far (think I almost have it figured out) my list is going to be: Quadzilla with Iquadbt & boost fueler & fuel sensor, Boss Mech lift pump, 100HP dap injectors, new cross over lines, VP44 with new electronics & 2 year warranty, BD Stealth kit (for VP44), cummins remote fuel filter/water seperator, stock lift pump relocator. (Boss Mech works with the stock lift pump for prime) Have a couple other items to add & It could all change by tomorrow. (no jet ski this year).lol
  24. Good Idea, I will check it out. Thank you. I assume this one: https://www.dieselautopower.com/ Or did you mean this one https://puredieselpower.com/diesel-auto-power.html
