Everything posted by IBMobile
Pics of me towing things
On a fishing trip at Brigeport, CA. About 65' long and yes, you need a CDL in CA to tow doubles.
AC Squeak = bearing?
If it was a bearing it would make noise all the time because the bearing is in the pulley that the belt is turning and when a bearing goes bad it makes a growling noise. The squeak could be coming from the belt tensioner when the A/C load is put on it. One way I locate noises is to use a 3-4 ft 5/16 hose. Hold one end to an ear and the other end to the suspect area. You can find and pinpoint noises along with vacuum and pressure leaks.
Why you never mix and match injector parts...
Solvent is good for cleaning oils and grease off. For varnish you need something stronger like throttle body spray or a good carb dip tank. In the old days carb and choke spray would do it but the EPA didn't like what was in it so I don't even stock it anymore.
Stupid fuel pressure gauge question
With the lift pump giving 12 psi there wouldn't be fuel flow through the pump for cooling but wouldn't there be fuel in the pump for lubrication?
Towing & 2 cyc oil
I tow about the same weight,and my trips take me from sea level to over 8,000 ft. I get 10.5 mpg going up and 13 mpg coming back, 400 mi each way.I thought about a oiled filter but the cleaning and oiling made me think about a bhaf. I found a 9" cone filter from AME that was a dry type and was washable. I've used it for about 20,000 miles and have washed it in a bucket of soap and water,came out fine. I did build my own heat shield for it. I don't know if it does any good but thought it was a good idea.
lift pump's gone bad
I just finished testing flow rate with no restriction, 5gal in 6.8min or 43.6gal/hr. That was with a 1/2" pickup hose and a 5/16" discharge hose. I took apart an old core and found the discharge side was 5/32". I could drill it out some ( 2/32") but it may not give me the results I'm looking for.
I've been thinking out side the box about using a bosch fuel pump and a pressure regulator. I can get the fuel pump new for app $100 or all most new for $25. the pressure regulator is $30. I all ready have the fuel pump, mounting bracket, and bushings in stock. The pump is used for 1983-1992 Volvos and puts out 90 gph and over 100psi. What do you all think? Yes it's a gas pump but I don't think diesel will hurt it.
How I should I add my Pressure Gauge and beyond
Here it is. I was able to get the photo off the hard drive and didn't use photobucket.
http://forum.mopar1973man.com/image/png;base64,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 here's my set up --- Update to the previous post... never mind, I thought I had the photo there.
How I should I add my Pressure Gauge and beyond
Thanks for the info. I'm not very good with these things but I'll give it a try tonight with a camera.
I put 4 gauges on the A post with the (from top to bottom) egt, trans temp, and fp gauge in the A post cover, and the boost gauge on the left bottom screwed to the side. I wish I knew how to put photos on here.
lift pump's gone bad
I'm leaning towards a Raptor fuel pump, the 100 gph unit. The set up now is fuel pump and a Nappa (10 micron) fuel filter on the frame rail plumbed with 3/8 hose to the main filter. I only use this truck to tow my 8k lb 5er with a 500lb boat in back of that. The truck has 69,500 mi and is lightly bombed. By the way I bought those "campaign" pumps in 06. This was "the fix" at the time, now we know better.
Truck will not start, fuel pressure @ 4-7 psi, flow after 30sec. app 8 oz. This will be the fourth pump. [*] :banghead: The last two were the "campaign" pump. I've read the thread "fuel pump issues" but the last post to it was March of 09. What is a good pump that will give me 17 psi, last for more than 50k miles, and not brake the bank?
