Everything posted by IBMobile
Turbo
If you don't replace both batteries the old and weaker of the two will draw down the new one.
Exhaust question,
"That seems sufficient to me" I agree.
Arrrrrrrrrr mike!
OOOh that's nice, but not cheap. It pays to have the right tool and it be reliable.
Might of screwed my my transmission? Help please?
I's not the band adjustment. Shifting occurs when line pressure becomes greater than governor pressure. The shift points can be adjusted by the transmission 'kickdown' cable. The more play in the cable the lower the shift point, it's like taking your foot of the throttle with out doing it.
Arrrrrrrrrr mike!
What kind of compression tools are you talking about, engine compression gauge?
$3.49
It's still going down.11-5-13 $3.419/gal, diesel $3.819/gal.
Trouble uncoupling WD hitch from ball.
Flagmanruss, can you just get a ball by its self, stick it in and see what's going on?
Hood sound insulator
Here in sunny So Cal I wax may truck every 3 months and clay it every 2yrs. The clear coat on the roof is just starting to show signs of failing. I still have the pad under the hood but it's starting to sag above the injection pump area.
The band will be fine if it didn't cracked and I don't think 30 ft/lb will do it. You say the threads in the case are fine then I think you dodged a bullet and should be fine.
Exhaust question,
I have a magnaflow 4" and I'm sure there is more than 1/8"clearance. Either the pipe bracket was put in the jig wrong or a broken motor mount letting the engine tilt to one side is all I can think of.
Lift pump placement
Picks of the bracket I made and where it is on the left frame rail.You can see holes in the bracket that were for the Carter pump and filter housing that was on there before.
Finally made the leap..
When one door closes another opens. Good luck with the new home and country living.
$3.49
11/2/13 $3.459 gas, $3.849 diesel
Lift pump placement
Before I put my Fuel Boss on I relocated Carter "campaign" pump to the frame. I made the bracket out of sheet metal from an old AAA sign. Cut a piece out of it about 12"x12" put it in a vice, heated it with a torch and beat on it with a 4# hammer till it had a 90 degree bend in it. Marked out where to drill the holes for the pump and a spin on prefilter. The other side of the bracket was slipped behind the metal fuel lines and bolted to the frame with #12 sheet metal screws and fender washers. I'm still using the bracket for an Airtex pump that's used to prime/back up the Fuel Boss. Don't forget to paint the bracket if it's made of steel.
$3.49
And the roads in R I are as good as here in CA "put you'r kidney belt on Ma, we're go for a ride." So much for HIGH gas tax = good road maintenance. :banghead:
Another twist to the ammo shortages..
I have ammo on hand. There's a Wal-mart not far from me and everytime I went in I picked up a box or two of this or that and put it away. I took inventory last spring and had a yard sale, made $1,000 on ammo I didn't want. Wolf 223, 150gr 30-30, lead 22lr, 9mm, and other stuff. the other day a friend stopped by to show me the box of 150 rounds of 223 from Wal-Mart for $75, that's .50/round.
24 valve cooling system problem..very wierd..check out!
I had a customer's car that drove me nuts. The only time the temp gauge would go above halve way and climb into the red was at freeway speeds, 70mph or higher. I'd replace the radiator about 1 1/2 yr before, so I checked fanclutch, temp sender, temp gauge, voltage stabilizer, and thermostat. I then checked the radiator, found it plunged over 50%. I had a rod out done at the radiator shop and no more problems. The higher the speed the more fuel burn, the more heat, and a blocked radiator just can't get rid of it.
$3.49
The cheapest fuel today 10/30/13: regular 3.54/gl, diesel 3.89/gl, at the no name mom and pop station.
Can this be a back door way, along with all the other things the administration is doing, to get around the Second Amendment? With out ammo a rifle is a club.
Cranking but wont start, just replaced heater core...
One thing I've learned, if you'r going to unplug ecm's pcm's ecu's or another control unit in a vehicle is to disconnect the battery. I've seen voltag spikes over 100voltes when a control unit is pluged back in with battery voltage going to it. The newer vehicles with the can system (combined area network) are even more sensitive.
Shortage here too. Califorina just signed into law no lead ammo for hunting after 2015.
Fog Lights
They look just like the 9004 blubs that are in it now. They slide right into the holder, twist the retaining ring on, and plug it in, there's no mods to do.
Fog Lights
I went to my supplier's warehouse to day and and yes they had them. The 9104 blubs with no R, 100/80 watt, for $5 each so I picked up 2 more.
Extreme cold!!!
I just binged ( not googled ) "truck cab heater" and all kinds of things came up. I'm sure some one that lives in cold country has experience with them. Here in San Diego by the coast, if it gets to 42 we think it's a 3 dog night.
Fog Lights
I called my supplier just now and he couldn't find a listing for the 9104R blubs, but this guy is not the sharpest knife in the draw to deal with. I'll be going to their warehouse in San Diego this week and ask someone else there.
