GSP7
Everything posted by GSP7
  1. Here is a Easy one , . !955 331 cu in _____________ V8,,, Fill in the blank Who-what?.... 331 cu in ______________ . OOPS sorry...... I got carried away and stole the thread
  2. Above was a Ford flathead V8 What's this one ...? Its got a nick name too ...
  3. OK kids,,,, Guess what this one is
  4. I'm Shocked I thought everyone knew the infamous Small Block Chevy ! .
  5. Yeah that's a cummins all right,,, You dont know what that is ?
  6. I too disagree with the statement that syn oil What does the "µ " stand for? I googled and cant find the info So a 15µ absolute filters finner particles than a 25µ absolute ? .
  7. That's a pretty blue filter what kind is it? I run the fleetguard StrataPore
  8. Mike , Were you at a RV park in Parma area? If so which one? Reasonable space rent? I used to always stay at that RV park in Sand Hallow, off Oasis rd, Country Corner RV, But it changed owners and price went way up and other rules
  9. Where'd ya go, deer camp? . I had a '64 Jeep gladiator J300. I had put a small block chevy 327, turbo 400 in it, sagnaw steering, adapters off a newer jeep wagoneer . Was a good 4x4. Had 4:27 gear ratio
  10. I saw Chris Ledoux in concert , Good show He got pelted with thousands of copenhagen tins thrown from the audience when he sung copehagen
  11. Grid heater, Mine is disconnected Someone was going to make a easy on/off switch disconnect, so you can use the grid heater to get it started in cold weather, then use a switch to turn it off (or disconnect), What ever happpened to that Idea or has anyone done this? What kind of heavy duty type battery switch is available
  12. Mike, Best thing to do is get a new puppy ! Ben at 7mos and old Baron, 13 years old
  13. Sorry for you loss Dogs are better than people
  14. Delo dinosaur oil here, and I run Delo in my gas motors too
  15. Mine does the same thing. Never problem with it though, .
  16. I'll have to look at mine,,, IIRC it is a black rubber plug with a vent under the metal cap
  17. Well what is the part number of the front inner wheel well fasteners? P,S, Looks like wesco doesnt have a website online store .
  18. Someday I should do the rear wheel cyl upgrade to chevy type. I assume the piston is larger diameter? Any one know both stock and chevy piston diameter sizes ? For comparison? Do the chevys have the exact same cast diameter that fits in the backing plate hole so it fits tight? Maybe a illusion ,but the chevy looks smaller diameter step that goes into the hole in the backing plate
  19. Anyone know if these style retaimers will work to hold the front plastic fender wells? My factory ones are similar except they are big plastic pop rivet type http://www.clipsandfasteners.com/Push-Type-Retainer-11-16-Head-Dia-7-8-Length-p/a14753.htm
  20. I have pre filled just a little. Most times I forget and dont prefil Im not worried about it being unfiltered oil, cause its brand new oil right out of he jug and I do oil changes in a clean room at a hospital and I dont change oil during a sand storm or in a rodeo arena with bulls and horses kicking dirt all over the place
  21. Hagger, What do you mean " "reference" to ground maybe going away" ? Do You mean the on/off selector control knob of the Three Knob unit on the dash is bad? Do You just mean the ground wire? So are you saying its probably the Three Knob Control on the dash ? The Three knob control a complete unit, I can get new at rock auto
  22. I live in the desert. If I move to where it rains all the time I bet that would keep the dust down Thanks for the bezzel info replies
