I saw somewhere on one of the Dodge/Cummins forums that it was possible to modify your air dam by attaching a Gen 2 air dam to the Gen 3 air dam.
I kind of liked the look of the deeper air dam so I thought I would look into it and see if I could make it work.  The air dam also has a purpose of moving air down under the truck to help reduce the drag on the underside of the carriage (thereby helping mpg's on the truck).
Now since I also have a Gen 2 vehicle it was pretty easy to measure things and evaluate whether it would fit well enough that I could be happy with it.
I took a few pictures along the way to document what I saw as I made the mod and what it looks like when it was finished.
First off are pictures showing the height of the existing Gen 3 air dam and what you see under the truck looking at the air dam level.
post-558-0-08755800-1441404817_thumb.jpg                                      post-558-0-83847600-1441404869_thumb.jpg
You can see that the bottom of the stock Gen 3 air dam is a little less than 17" from the ground (with my 19.5's on) and you can see what hangs down from the undercarriage below the bottom level of the air dam.  Looks like a perfect place for lots of air turbulence and drag.
I ordered an aftermarket Gen 2 air dam on ebay and got free shipping and it cost me $64.  I didn't want to spend a lot of money to try this out so I decided to go the ebay route rather than buy from the dealer and save myself over a hundred bucks.
When the part arrived I was really impressed.  Very good quality and thick material and wasn't flimsy at all.  So I got a couple of small 'C' clamps and clamped it in place on the lip of the existing Gen 3 air dam.  When I was happy with the centering of the unit (both side to side as well as back to front) then I drilled holes in the lower lip of the Gen 3 air dam and bolted the two versions of the air dam together.  I used large pan head 5/16 x 18 screws with washers on both the top and bottom lips where the air dams are joined.
On the end of the Gen 2 air dam I had to muscle the curvature of the air dam to better match the curvature of the Gen 3 air dam.  Turns out the Gen 3 air dam is a little wider with a slightly different curvature as the end turns back toward each wheel.  But everything bolted together pretty well and it looked like it was made that way.
So here are some pictures of the finished product.
post-558-0-87912700-1441406122_thumb.jpg                                            post-558-0-48826600-1441406169_thumb.jpg
I also took a picture from the front to show the new ground clearance of the air dam as well as how it has now covered up a lot of the undercarriage that was visible previously.
post-558-0-72363600-1441406371_thumb.jpg                                              post-558-0-01673100-1441406406_thumb.jpg
Haven't been out much on the road yet so I can't tell if there is any measurable benefit ( but I will be hoping).  :hyper:
  • Replies 15
  • Views 4.1k
I have thought about this mod before but never pulled the trigger. I am looking forward to your results.
I'm going to say there is going to be a gain but small say about 1-2 MPG. I orignally ditched the air dam off the 1996 Dodge Ram. Now when I reinstalled the airdam again I found a small gain with it. So I would say its worth the effort. But don't expect huge gains.
It looks good, like it came that way. i would take 1 to 2 mpg. Question,  Is that a Idaho tag I see on the front of your truck?
Roger on that! :thumb1:
Roger on that!
One more question, Does it really say Famous Potatoes on it? If it does Mike has some "splainin" to do.
Edited the post so its readable
Roger on that 2!
an increase of  1-2 MPG would be pretty big in my book, I'd take that any day and be happy with it.
Be careful off roading!!!
Ya, I won't be pushing any snow or riding in the bottom of deep ruts! :)
I expect John to be mostly a pavement queen with those tires.
Yup.  These tires will never see any serious off road conditions.   Been on some forest service roads but nothing where there is mud or snow or blazing a trail.
In fact these tires are only on the truck from March thru October each year.
Pavement Queen, huh?   That's a badge of honor! :cool:
Kind of like the Black Lions HT's I'm running. But I'll run them year round.
http://www.blackliontires.com/tires/BC86.html
So far really good wear characteristics. Same reasons I went to those as you did to the truck tires.
How about the air dam have you seen any improvement wise in the MPG number?
No update yet.  I've only put about 50 miles on the truck since I did the mod.
I'm thinking a road trip has to be in the cards pretty soon. :whistle2:
