- Replies 12
- Views 5.6k
stevens cummins 5 posts
Me78569 3 posts
KATOOM 2 posts
Haggar 1 post
I am seeing it as a 4333N national. Found that in a Timken cross reference catalog. I attached a copy. Search for 4333N. you will find a GM and chrysler cross. HTH Hag NSCO
No no leak just had to pull the drive shaft for joint replacement, if you have a leak check for drive line vibration. Plugged transfer case vent. Or play in tail shaft of tc
Unfortunately leaking tail shaft seals are common. I've been through a few and I still get a slight weep.
Hay guys could you give me a national seal number for the the transfer case output I'm 99.9% sure mine has the np241DLD but everyone keeps giving me the larger seal I'm assuming for the DHD
