Pyrometers install
So I have another pyrometer question. I realized today, while working on my fuel leak, that the dude that installed the pyro in my truck tapped the manifold on the wrong side! Meaning the front side of the manifold outlet rather than the rear. Anyone have an idea on how much hotter the back side normally is? Also, if i wanted to fix this, could I just plug that spot and drill and tap the rear side?
What could you use that would plug the hole and stand up to those temps and heat cycles? Just curious because I've thought of worse case scenarios where drilling and tapping this goes wrong, what would be the best way to fix it. Only thing I could come up with was a whole new manifold, at least that's what I'd tell the wife! :lol:
Lol idk I figured just a steel plug...I really have no idea though I'm hoping someone who knows a lot more than me will chime in because a new manifold is definitely not happening anytime soon. I don't even wanna drill a new hole and move the probe. So I'm hoping for some opinions on how much hotter those rear cylinders are as well as advice on how to fix it.
That's an idea. Well truck usually idles at about 250° to 280°. 3 cyl high idle is lower, around 175° or 200° if I remeber right. maybe the probe in the wrong location explains that? Not sure which cylinders fire in 3 cyl? Today on my way to work it's raining and about 35°, and my drive is mostly rural highway. Highest my egts got was a little over 800° in fifth gear climbing a decent grade at about 60mph with 12-15 psi of boost. Normally at about 65mph or so on the interstate I see 600° to 700° on flat and small hills. But it get up in the 900° to 1000° range for some of the really steep hills. Sorry I don't know grades... I also noticed the other day with the comp on 3x5 accelerating hard and about 30-35 psi I think I may have hit 1100°, might have been a little lower but def hit 1000°. What do you all think?
Does not sound out of the ordinary to me. I might see 50* more than you cruising level ground but climbing a grade sounds about right. All depends on how far you stick your foot in it.
Edited by dripley
That's true. I'm just worried about it since everyone always says to put it in the back. I can't believe I never realized it before. I always thought it was in the correct spot. Next questions then are can you plug one hole and use a new one without issues, or should I just get a new manifold? If so which one? Three piece?  Do you have the hi idle switch to know what temp your at in 3 cyl mode?
4 minutes ago, Buzzinhalfdozen said:
Those temps sound about right, wouldn't mess with with it if was mine. A pipe plug would seal up just fine if you decide to drill a new hole.
Just a normal npt plug? No thread sealant could stand those temps I assume? Can I reuse the original pyro probe or would I need a new one?
4 minutes ago, Mopar1973Man said:
3 CYL mode is about 800-900*F with an exhaust brake, about 600*F without.
See that's what concerns me, I do not have an EB, but my 3 cyl temp is way low, like around 175-200 if I remeber right. The truck still warms up just fine though. Could that be due to the probe location?
Just now, dripley said:
I dont know which 3 fire, but if it is 2,4,and 6 you would not be reading but one live cylinder. Could be the difference. If you plug the hole just put anti seize on it. Personally I would just leave it alone.
Yes that's what I was thinking but idk which three fire either haha. Well that's two people now that told me they would leave it so maybe I should listen lol. I guess if you guys wouldn't worry about it I shouldn't either. I was just concerened about how much hotter those rear cylinders might be getting....
