Front Crank Seal Help .... and show and tell of what the dealer did
check this out write up out, notice that i reinstalled the timing cover " bolts only HAND TIGHT" and then install the seal
http-::s1209.photobucket.com:albums:cc389:rburks1:Crank%20seal%20install:.webloc
YOU can find the complete article over in TRUCK ARTICLES ON THE FORUM
The finished product.  I am leaving that loctite 620 in there.  hardens in 24 hours.  ZERO of it is touching any seal material or yellow sleeve.
i won't know until tomorrow if depth is right... but... i used the cummins tool so hopefully when I do the install, all goes well.
i installed mine by hand on original oem cover on a workbench. started it with fingers and tapping with deadblow to get it in, then with a 2x4 i whacked it till it was flush with lip, then used the install tool which set it into the housing about 1/4" (from front) and it has worked fine. strange you have so many issues with yours :(
just found my baring location has no rubber gromet in it.  dunno if the dealer left that out or one wasnt in there.  he just did a valve service.  likely forgot to put it back in.
Got er in.  don't mind the locktite 620.  thought it would have hardened by now, but still goopy.  oh well.
seal is a hair cocked, but square in the cover.  really weird.  i tightened the right side of the case down a bit harder to compensate.
waiting for ultraback to hardened for an hour per instructions, then torquing to spec
you might like this redneck engineering.  i went to lowes and got 3 M8x1.25 120mm long bolts.  threaded them through the cover and used that to perfectly align the cover before pressing on the cover w/ ultrablack.
my seal work.  i found i had to scuff the back of hte cover to get the ultrablack to stick.  first attempt it literally slid right off.
Edited by bms231
got her buttoned back up..... tired
i wound up not starting her.  rotated the crank by hand twice.  book says let her sit four hours dry.  i am going to let it sit 24 hours b/c ultra black says wait 24 hours before putting vehicle back into operation.
fingers crossed.
Very, very impressed with the idea of the bolts.
Like I told @bms231 I'm going to purchase a set of bolts for this reason and keep them in my toolbox for future jobs. I'm sure soon I'll be doing more gear case resealing. Then his idea of pressing the speedy sleeve on with the damper. Again another very smart idea.
So I got to give Brian a big High Five for great ideas neat tricks and idea!
Started her up tonight to bleed the coolant system.  Let her bubble for ~30 minutes.  So far 45 minutes run time on the truck.  Fingers crossed... no oil as of yet.  Don't want to jinx it.
Waiting on a part from dodge.  Stupid dealer never put the plug back in my bell housing where the barring tool goes.
That's because most Loctite products are "Anaerobic" which means they will only cure in the absence of air, which is why the exposed product will never harden. One needs to use Loctite primer for an almost instant cure of most of their anaerobic products. The bottles are actually designed to allow air to flow through them, if not it would be solid in the bottle much like the product usually is under the cap.:wink:
One needs to research the products and how to properly use them before just assuming how they are to work.
You did however choose the retaining compound with the largest "Gap fill" spec of .015". to help with the nicks and gouges on the crank.
Not to be a buzz kill and hopefully as many issues as you had that the seal lasts for a while but from my experience if the seal is not straight and plus the fact you installed a seal that is made to spec for the crank dimension alone and not with a sleeve under it rather than a matched seal sleeve kit it will not last as long and will wear into the sleeve fairly fast and start to leak.
Edited by Wild and Free
1. used the Cummins seal kit per the thread. so it is a match set of sleeve and seal. oem cummins. even called them with my engine code to confirm.
2. researched the 620.  said it above which is why I selected it for the gap coverage. originally had the stick, but saw the gap coverage wasn't as great as the liquid for.
3. read the instructions on the bottle, their site, and technical spec doc. mentioned primer, but never exactly said why. most spray paints say use primer but 99% of the time it's not needed. figured it was just another add on and acetone cleans just as well.
so.....I waited 4 days. on the bottle it says cure time of 24 hours. the way they word the primer leads me to believe nothing about required use.   designed to promote the curing speed of LOCTITE anaerobic adhesives and sealants without any significant loss of joint strength
Edited by bms231
bms,
The stuff where no oxygen is will cure.  The goo hanging out on the outside where it is surrounded by oxygen will not. It will stay gooey.  This is why the 620 doesn't harden in the bottle....  In fact if you try to pressurize the bottle, it will leak, its made so that our ambient oxygen will migrate through the bottle and keep it from hardening.
The primers work pretty good and help clean the area, but they don't do anything to cure the the goo that is exposed to oxygen.  If you want to cure the stuff on the outside you will need to make an oxygen free atmosphere for it.  It appears that acetone or iso-alch will act as a solvent and remove the un-polymerized portion
HTH
Hag
Haggar hit it on the head with the Loctite as I was trying to. I did not say Loctite primer was necessary I was just merely explaining why the excess product would never ever set up, primer can be used as a cleaner yes but the 24 hour cure time is for the product in the area void of air between the crank and sleeve alone with no primer use, with primer it is a few seconds to just a few minutes depending on product for cure time is how it works.
Sorry had to go back through and reread the thread , missed the post about getting and using the matched kit.
On ‎4‎/‎4‎/‎2016 at 8:20 AM, bms231 said:
I was honestly thinking of using this autozone sleeve.  use a little bearing mount to mount it to the crank.  then use the stock cummins seal over it.
http://www.autozone.com/internal-engine/crankshaft-seal/duralast-crankshaft-seal/dodge/ram-2500-3-4-ton-2wd/2001/6-cylinders-7-5-9l-turbo-diesel/630211_726041_4222/?checkfit=true
I saw this on another thread.... is this thing even seated far enough back?  Does the seal run along the backside lip or anywhere on the "repaired" sleeve portion.  I assume the later.
For the speedy sleeve in the pic above the installation ring "The lip portion to the inside" which is what the install tool cup is for and pushes against is to be torn off the actual sleeve after install, There is a perforated area that it will separate at.
On 4/14/2016 at 2:25 PM, Haggar said:
bms,
HTH
Hag
Thanks dood.  Definitely get the anaerobic meaning... but didn't realize it was actually anaerobic.  Kinda has me worried now about this stuff setting not setting up ever and causing leaks.  Everyone said use loctite.  service manual says mopar bearing mount.  figured loctite bearing mount should be the same thing.  hopefully it holds.
well.. been a week and out a few times.
my fix has held longer than the dealer's two attempts.
first trip out I left a coolant puddle in home depot's lot. upper radiator hose wasn't tight enough. if that's the worst thing to happen I'll take it.
That one reason I still love the old spring clamps. No guess work. Slip it on and release. Always a good clamp.
