Quadzilla Adrenaline V2 Testing
TFaoro
On ‎11‎/‎19‎/‎2016 at 9:36 AM, Me78569 said:
Too, I never save those.  I'll post them sometime, but you can just highlight all columns the. Insert a line graph.
@Me78569 Try this tool  I created to populate the graphs automatically. the instructions are in the .zip file. let me know what you think, I am getting good results with it and its quick.
Quadzilla Data logging.zip
On 11/14/2016 at 4:25 PM, Dieselfuture said:
Did some harsh testing this weekend , still have the engine intact :), but my boost sensor is reading 2psi minimum. is it just time for one ? or how can it go bad with you guys running 60psi or better, I hit 45-47 max which is a bit much for a stocker. I cleaned it but it doesn't change still reads 2psi, from there on it matches my mechanical guage.
Ok got my adapter from genos the other day, changed my map/boost sensor and quad still says I'm at 2psi, what else can cause this.
Cool setup.  @Carbur8tr might try to add this to your macro.
let me think about this.
Try flashing a old pre v2 flash and let me know if idle shows as 0
Edited by Me78569
Quadzilla needs a data logger like the OBDlink App has. You don't have to import anything to excel or anything its all self-contained. The problem I've got is the limited time it logs data and the requirement to email myself where I don't have any cell service so I rather not bother fighting to get apps to export from one to another just to see logged data. If the data was saved directly to a file period I would be tickled.
I export to FX explorer as a CSV.
It's a little clumsy, but compared to the other vp44 data loggers ( there are none) it is great.
@Dieselfuture
 Been mulling over your 2 psi issue.
The quad reads boost from the ecm from 0-16psi.  If you are seeing 2 psi at idle that must mean that either your quad is flashed with an older flash that had issues or your ecm is reporting boost at idle for some reason.
Try to reflash your quad with the flash in this sticky
https://mopar1973man.com/topic/12025-how-do-i-manually-install-the-quadzilla-driver-load-the-quadzilla-v2-tune-on-windows-10/
@Dieselfuture
Is this flash updated with your new wire tap update?
this 2psi thing started after some hard driving with new v2 flash (your first v2 flash available to public), I thought boost sensor was old and something happened to it. I'll try this new update and see. Thanks.
Did that change recently?
Both late and early trucks are reading boost via the canbus message so if idle is reading 1-2 then the ecm is reporting that.....unless I am calculating boost incorrectly from the ecm, IE cummins didn't follow the standard layed out by SAE.
@Carbur8tr  What is your truck reading for boost at idle?
Edited by Me78569
