- Replies 14
- Views 13.4k
Wild and Free 5 posts
Mopar1973Man 3 posts
JAG1 3 posts
Dieselfuture 1 post
EGR valves are notorious for plugging up the intake system with an oily carbon mixture that is really hard, this one is packed solid. If you look at the picture the intake tube is taken off and the in
No. Just remove the intake cover plate and use a shop vacuum and a tool of some sort to remove the build up. Cummins isn't the only one with this problem even the VW diesel are really bad
That's incredible. thanks for explaining. Now I know why second gens are holding value.
Wonderful 6.7L EPA garbage. As you can see the EGR valve has loaded up the intake manifold with soot choking the engine for air or boost pressure.
Enuf said...
