Going Crazy with Quadzilla Install
BigPimpin
20 minutes ago, Me78569 said:
PLastic housing and an excited installer can lead to issues pretty easy.
They have a steel nut embedded in the plastic... It'll probably plow through the PSG before stripping any threads. That said, if a user doesn't follow instructions that's a personal problem :lol:
I used the term plastic loosely. More nylon like than plastic but not sure what it is made actually. His site says plastic that can withstand 600* F. He also has good instructions there now. I dont remember them back in 09. Of course there are alot things I dont remember from back in 09.
Just an update on my ongoing install.
I purchased the Vulcan big line fuel kit and had one of the threaded connections break off while installing it. Had to get another one shipped 2 day express, which took 5 days. Then the hose itself leaked and had to run out to buy some hose clamps for that.
Now, after finally getting everything together, I had to tighten the needle valve because it was leaking, and sure enough it broke and it spewing diesel everywhere.
So I decided to come in and have some ice cream while I contemplate my next move. Looks like I'm going to pull all of that junk off and put my original fuel line back. I can't believe I over tightened those two things when all I was using was a small adjustable wrench. Either the quality is bad, or I'm a lot stronger than I think- which doesn't seem likely.
Either way, I'm bummed. Sorry for the rant, it's just been nothing but problems trying to get this stuff going, and it should be easy.
