If you could go back in time when your truck only had 63K miles
13 hours ago, Me78569 said:
I am sure they stretch some, but the compression of the gasket is what I noticed after a week.
as for the articles, heres the gold
https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/
Thank you very much!!
@Me78569are you saying your existing gasket compressed that much after you upgraded the studs?
@jlbayes how many lbs do you have yours torqued down to?
 All right guys I got an update, I got the new ARP head studs installed!! That took a couple hours in the 90 degree heat!!!
 I also installed the injectors with everything torqued down to spec. Also adjusted the valve lash while I was in there. Then I went to fire up the truck the truck started after being bled however it had a horrible miss. I loosened all the lines and every line but three affected the idle so I realized cylinder three was the cylinder that had a miss. I then took everything back apart and switched injectors with cylinder three with the cylinder one injector everything looked good reassembled it and now I have a miss in cylinder one, I believe I may have been shipped a faulty injector......
What do you guys think?
This is beyond frustrating I now am becoming a pro and when I get a new injector I will get to do it yet again. Hopefully third time is the charm?
I took a video here is a link.
https://youtu.be/Ow5asK0Ijjw
