Shrader valve leaking
hey guys my shrader valve is leaking how do I order a new banjo where the shrader is in it to match the one in my 24 valve, can I just cap this or do I need to order the one made for a fuel pressure gauge and just go ahead and do away with shrader valve
Vulcan does have a cap you can put on it. I have one on mine. The trucks came with a cap on it. That is the one I have on mine. You could just replace the shrader  valve itself. Vulcan might even have that. If not the big line kit is a good option like @Me78569 suggests.
I would think you could remove the valve and replace it.  It's probably larger (and better) than a tire valve but it should come out.  134 freon conversion kits come with new valves so I'm sure you could locate a replacement fairly easily.
L8tr
D
guys I appreciate help I just ordered one of genos for 7$ without the shrader. and I guess it was just debris , because after fiddling with it trying to find something to cap it , it don't leak no more I guess the rubber sealed again
13 hours ago, Mopar1973Man said:
There is an another option to go to a tire shop and get a new shrader and just change it out. You can use the tire tool and remove the old one and install a new shrader valve.
It is just a tire valve and what I have used with no issues.
