Just got this coming https://m.summitracing.com/parts/POS-400
As mine is getting lazy and I always wanted 2wd low for backing up trailer. Does any one have one installed want to shear thoughts and pointers. I got it from summit as there are some China made out there. Hope I get the US made.
This is straight from Posilock site http://4x4posi-lok.com/genuine-4x4posi-lok.html
Edited by Dieselfuture
  • Replies 40
  • Views 12.4k
  • Tractorman
    Tractorman
    I installed a vacuum operated switch ( a GM heater / AC control from a wrecking yard) years ago.  The cost was $5.00 and it has worked for over 250,000 miles.  I think it is the best option because it
  • Dieselfuture
    Dieselfuture
    Just want to update this, got my posilock put in and it was pretty easy aside from routing cable and figuring out adjustment. I did come out fire wall and under intake horn and over driver motor mount
  • I know nothing about the product but I do like the concept. I have thought about doing it myself also. To many other things in front of it for me right now.
Edited by dripley
I think I might of posted this in wrong place,  please move this thread where it belongs.
I've had mine for about 4 years and no real complaints. It can be a little screwy to get it engaged/disengaged but no worse than waiting for the vacuum cad. Just make sure you get it engaged before you need 4wd or you'll be trying to rock the truck back and forth while pulling on the knob and inventing new curse words.
To disengage: I've found that if you're rolling forward at slow speed hold inward pressure on the knob and stab the brake pedal a few times. Seems to help align things and pops right out.
For routing the cable, I would go straight out from the firewall over the motor mount and make a long sweep down to the axle. Mine is routed differently and has some  tightish bends and that might be why it gets a little sticky sometimes.
I personally dislike the looks of the kit. I'm working on finding some electric over air switches so I can have it engage when I want it to.
Are you going to use an air cylinder to operate CAD?
No, I'll probably keep the actuator. I'd like to implement one of these two drawings. I just haven't searched for what valves are available.  My issue is different though. My transfer case does not have a syncro in it, so it's impossible to put in in 4wd while moving. I'd like to be able to actuate the front axle during the winter that way I have 4wd on demand during the winter.
I would prefer this one! Single switch.
I am looking at something similar. Was a write up at TDR. Fella used a vacuum switch for a Honda I think.
If you could find a link I'd really appreciate it!
I "think" this is the same concept as the 2low, but I'd have to see the schematics.
Unsure how to link. I could email or text article to you. I am afraid to do too much, don't want to lose it!!
You can just copy and paste it in. If not, my email is tyfaoro@gmail.com
8 minutes ago, Royal Squire said:
There must be a vent or factory system would not work, right?
There is. The factory block on the transfer case has vent, vacuum, then a line to the open side of the actuator and a line to the close side of the actuator. I need to eliminate that block though so I can engage it without putting it in 4wd.
Somewhere in the past here I have seen a thread with a simple bypass of the vacuum the engages the 4wd and gives you 2 wheel low. Dont remember where I have seen it here but it exists maybe in the archives. Cant be that hard to do.
48 minutes ago, TFaoro said:
Got it. http://dieseldatabase.com/two-wheel-drive-low/?id=10
This won't work though, because there is no vent. Without that, the actuator can't move.
Click ^^^^^ link.
12 minutes ago, TFaoro said:
Click ^^^^^ link.
So it I were to go out to my truck right now and put a clamp on my CAD actuator line and put my truck into 4wd it would not give me 2 wheel low?
It would, but I'm trying to build something that actuates both directions.
