Torque Converter Rattle
- Replies 13
- Views 6.9k
CTcummins24V 4 posts
notlimah 3 posts
Evan 2 posts
Dynamic 1 post
Called the experts at Goerend, they want a video of the sound. Then Dave G will call me back with a diagnosis, and if it's the TC I will have Goerend rebuild it. In the meantime, I checked
It's definitely possible to have a rattle in the converter, but it doesn't happen often. As long as all of the bolts are torqued to specs and you're still getting the noise, it's definitely a possibil
I had a TC bolt back out sitting in the case/adapter hitting the flex plate, fixed that. Used red loctite on everything, all bolts are tight, billet goerened flexplate installed. Still getting a rattling sound when the torque converter is locked under load. I think the noise is coming from the TC, not the motor, because it only makes noise in lock up. Hard acceleration in 1st 2nd and 3rd is noise free. Truck idles fine, no abnormal noise. After doing some reading, some cummins people complain about ATS torque converter rattle and early 7.3s too. Anyone ever heard of this? Converter is a DPC triple disc. Transmission shifts fine, no slipping to my knowledge. @Dynamic?
Valvetrain?
