- Replies 23
- Views 5.8k
gipperkid 7 posts
nukethenazis 6 posts
Mopar1973Man 4 posts
015point9 1 post
You'll need to get 4 12v or higher, 1 amp diodes and 1 12v, 125 ohm resistor, all of which can be had from The Source I believe. Solder them together like this: I pulled the be
Captured and moved to the article database. Thank you!
Changing my manual mirrors to power, heated, and lighted. I know doors are pre-wired for the power/heated and I've already added the mirror control swtich and the temp control with heated button. My question is if anyone knows if there is lights-on power source inside the door. Looking to avoid running wires through the dash to the light switch.
