So I got to test idle pressure at the filter canister with a friends short hoses tester. It read same as the edge monitor. 17 18 psi idle. Revved to 1200 and had 15 16 psi. Seems like the edge is spot on so far. I do have the Vulcan diesel tester on the way to test wot pressures. Now I’m really stumped as to the cuase of the drop in psi... Maybe the pump is going bad slowly? I have heard of a ball
and spring hat is adjustable inside the ddrp should I try that?
My DDRP was losing pressure so I took it apart & stretched the spring a little bit.  I have great pressure now.  It's pretty easy to do just remove the aluminum plate & the ball & spring are right there.  Take notice if the ball is deformed at all as you might need a new one.  Take care of the O ring too. This could get you by until you upgrade.
L8tr
d
L8tr
d
I believe I will try that Saturday along with the valve adjustment! Thanks
56 minutes ago, SilverMoose said:
I think the proper length of the spring is 5/8".  Google it and you will see a bunch of info on it.
Here's my post about it
L8tr
d
Obviously when I remove the lines from the lp fuel is gonna spill and likely run back in the hoses. Will it prime by itself when I’m done or will I need to bleed something?
21 minutes ago, Mopar1973Man said:
I normally use a pair of vise grip needle nose pliers to clamp off the fuel lines to prevent a mess and losing prime.
My pump to filter hose looks pretty worn and cracked. I’ll problably replace them Ll with a big line and banjo fitting kitnif the pump ends up being ok
@SilverMoose how do I get this aluminum plate off??
Well guys apparently the lift pump has been replaced since the Fass was on there because this pump looks nothing like the other Ddrp pumps. There was a number on the outside that said e7153. I googled it and come too find out that it is a airtex lift pump!!! Now I’m not sure what to do! Has anyone had experience with these pumps? I defiantly think a new lift pump is in order.
Here is a pic of this pump.
I readjusted my valves yesterday and they were a little messed up so maybe his is my mpg thief? Doesn’t seem like it would take almost 4 mpg out. Next thing is going to be injectors. Thinking that that is going to fix the rest of mpg as these are original with 127k on them. How long have you guys went on original Bosch injectors?
