Lost mpg
So ever since I had the drop in fuel pressure which I have not mechanically tested yet my fuel economy has steadily went down since then. Have not had the chance to hand calculate yet but lie o meter says it went from 16.8 to 14.3. I picked up a tester today so I’ll be able to rest idle pressure soon. Where do I hook up the tester?
The pressure went went down and then back up to 17 18 at idle and 12 13 wot.
Used to be 19 20 at idle and 15 16 wot before the drop.
  • Replies 124
  • Views 22.1k
  • Use two pair of needle nose vice grips with vacuum hose pushed over their jaws to clamp fuel hose and adjust to fit hose.   I've used this setup on heater, fuel, brake and transmission hoses with no p
  • yea you are idling WAY to long.  I typically give her 30 seconds on a close start to stablize oil pressure and rpms at idle before I take off.  all you are doing is burning fuel.
  • My belief is if the truck knows you like it, then it will break because it rules the roost.  If the truck thinks you dont care about it then it will work fine.
10 hours ago, Mopar1973Man said:
Remember as cetane RISES the BTU's FALL!
This is an ASTM testing label scale for cetane and BTUs. The Dark green is typical summer fuel where the light green is winterized fuel. These are not always exactly these number but it shows the relationship.
cetane-btu3.jpg.718cdb12cd43873ccaa0be5d
Point of Reference: Gasoline is just below the 120k BTU mark...
https://en.wikipedia.org/wiki/Gasoline_gallon_equivalent
Colder the air the steeper the timing curve. This can be harmful to MPG because the fact the ECM can measure temperature of everything but can't measure the cetane of the fuel so it could be slightly over timed. Hence this where my MPG fooler was created for.
Then there is wind resistance difference. Colder the air is denser so you got to travel roughly 5-10 MPH slower to equal the same drag as summer time.
Lube oils in the axles are going create some drag till warmed up. Being super cold like minus weather it might never really warm up much.
Thanks for the graph! Very helpful. I would love to purchase an mpg/ high idle switch from you!  When do they go on sale?
Im seriously thinking that the weather is what’s causing 75 percent of mpg drop. Liometer when I had the edge ez said 16 so it was prob like 14.5 and with the qaud it said 17.5 which was prob 15 16 mpg. Still I think that is too low for a Diesel engine with low miles.
As far as injectors with the the qaud I can actually tune them to help mpg right? Or would I be better off with 100s or 75s?
Been on sale the last half of December. Just went off sale 2 days ago.
Any tuner will foul the overhead trip computer. It's no longer even accurate or even close.Quadzilla can make the the overhead computer go both directions just in the way you shape the fuel map. Too much fuel cutting will go down, excessive smoke in the tune can make it go up. The only true number is hand math.
Then biggest thing is getting a fuel map that is not overly low on the start and not going all the way 150%. @Me78569 is right you can run up to mere 120% it will do fine for a daily tune. So my latest tune is 90% to 120% fuel map. Then timing I RETARDED 1.5 degrees to compensate for cetane levels of the local fuels.
Truth is Quadzilla when it takes over there is no need for the MPG fooler so I'm trying to tune strictly without the fooler. The only time I'm at a loss is warm up time.
Bummer I should have picked one up.
Lol, I just got one on the 31st, thought that's when sale started, that's alright though you deserve a full price. :spend:  :truck:.    :burnout:
Agreed! When I get some more cash I will get one!
This is why I giggle when I hear people adding even more cetane booster to already high cetane winterized fuel then whine about how bad the MPGs are all winter long. One of the few reasons I like 2 cycle oil it a natural cetane reducer. It will help with MPGs just slightly.
Guess what? I’m going out to dump some in right this minute! Haha! If your ever in the St Ignatius Mt area let’s grab some dinner and talk trucks! :cummins:
Since chances of that are very low we can always hook up on the phone then I can explain in depth about the theory.
That would be cool! I’m sending you a pm here shortly.
I know that idling for long periods of time are hard on fuel economy but I’m also wondering if idling for 15 minutes every morning is too long? Will that length of time cuase cylinder wash down?
Way too long... 1-3 minutes tops. Typically I would fire up and be rolling fairly soon afterwards. My problem for me is that I'm stuck waiting for @MoparMom down in Ontario, OR in cold at +10*F last night I wasn't going to shut down. I left the engine run, heater on and the exhaust brake on just to keep the pyro up so the engine wouldn't cool. This is enough to absolutely kill my MPG's with 30 minutes of idle time. Idle time without speed is very non-productive.
Is it not hard on it too take off before engine is warm? Obviously when I get the high idle switch warm up time will drop
I typically attempt to bring the coolant temp up to about 60-100*F I'm gone. It's now no different than a summer morning start and take off. Way too many wait for heat or the coolant gauge to rise.
Like yesterday morning. I timed it right. I fired up pulled the truck out of the garage. Set the 3 CYL high idle. Continued to pack MoparMom and any myself for the day. By the time I was locking the front door and ready to head out in the +10*F weather the truck was warmed up to 150*F still on 3 CYL. Cancelled and rolled on. I never attempt to completely warm up but in my case MoparMom being 81 she thin skinned and can't stand the bitter cold so having just a bit of heat in the cab isn't bad and kept my idle time to minimum.
I defiantly need the switch. This has to have something to do with my low fuel eco too.
Well I’ll be darned! I always thought it was very hard on them to take off while cold.
meh, just dont drive like a crazy person until you get heat into it.
Defiantly will be cutting down idle time! Lol also will be buying an idle switch.
I'm surprised to hear that you guys just get in and go. I always have this guilty feeling if I drive before things are warmed up. I guess I just always assumed it could do damage. I use my ears a lot when I drive, and when I hear something different, I assume something is wrong, or in danger. I never thought about just not driving it hard...:lol2:
You and I together! Lol I’m the same way I always listen. Sometimes I’ll gontonwork and never turn on the radio. I’ll just listen for odd sounds! :iagree:
Hehe I think you’re right! :woot:
