Not starting after warm
So after doing some hard searching we where able to find the issue I hope. The funny thing is i just replaced it last week with a cheap one from Oriellys. The fuel pump relay. Replaced it with a Dodge relay and it starts right up with no issues been tested all day so far. Hope this is it.
2 minutes ago, dripley said:
I believe @Dieselfuture is asking where the relay is installed. In the PDC or an after market harness. My money is on the PDC for the VP.
My bad it was in the PDC for the vp.
2 minutes ago, Mopar1973Man said:
If so there should be a P1689 error code from the relay failing and the CEL should be on.
I checked for codes with my Scangauge II and there was none. I will check with my smarty s03 tomorrow.
