Going to install an exhaust brake looking for Opinions
  • Replies 48
  • Views 12.4k
  • I loved it. I had to get rid of it in 2007 when I went to a different charger.     I used it all the time year round.    Absolutely fantastic for warming the vehicle up vs just hig
  • I had a BD turbo mount on my old truck. I loved it. Zero issues and used it all year whether towing or not.    Had the arming switch on the shifter and there was a micro switch on the thrott
  • Mopar1973Man
    True... But you typically have to custom order that downpipe.
Had the arming switch on the shifter and there was a micro switch on the throttle.
Brake activated when throttle was in neutral position.
Saved my butt a few times.
You state you are going to install yourself.  My BD is not user friendly direction wise but it works better than my in-laws Pac brake in his 7.3. We both agree.  Unsure what models we each have.  Or if our 2nd gen has more compression or what ever.
I think if buying again I would go with Pac brake if directions are better and if they had phone number in US.  I spent about 20 min on phone with BD tech dept and surprised by added charges on phone bill.  Maybe different now in 2018 than 2008.  And I think Pacbrake has more support if you need any.  On my exhaust thing there are 2 ports that are plugged off with brass plug.    1 for temp probe and 1 is test port.  I didn't need either (never touched)  but the plug for test port came out going down mountain pass.  Made he'll of racket and burned hole in rubber strip that goes across.  That is when I called them. Beyond that has worked excellent and wouldn't be without one towing trailers on grades and.  ? and wife no longer telling me to slowdown.?
Edited by 015point9
Screw up
I have the Banks. Bolted right and and worked great until 6 months ago. I think something in the actuator went, but not sure. It is possible I have some vacuum leakage that could be the culprit. Not getting much time at home lately to check it out. Has around 165k on it and worked fine right up to the day it quit.
I got a BD the one that replaces a back flange on the turbo, I thought installation was fairly simple just took some time  to install. Works pretty good especially in higher RPM.  just need to consider if you're ever going to upsize your turbo from 3 to 4 inch, then you probably should look at in line installation vs the ones that bolt to turbo.
I've got 4-inch exhaust bolted on my exhaust brake and no issues. Even with the 3-inch exhaust, I didn't have any issues.
 does your exhaust brake flange come out as a 4-inch? If that's the case I'll definitely go with your setup, mine is only 3" then  bushes out to down down pipe that is 4 inch and then it turns to 5 inch
 I heard where people put hx40 or something like that on with a 4 inch downpipe right from the turbo, what I mean is it doesn't bush out it's true 4 inch
You are correct.
When I went from HX35 to Super B I had to lose the exhaust brake due to the Super B now having an HX40 outlet and requiring an HX40 downpipe.
BD's and Pac Brake's websites even mention this. Although Pac Brake's is a little more vague stating an additional adapter is needed and I was unable to find that adapter on the site.
https://pacbrake.com/product-search-results/?product_year=2002&product_make=Dodge&product_model=RAM+2500&product_line_type=exhaust-brakes&search_type=product
https://www.dieselperformance.com/shop/product/2033137-exhaust-brake-1999-2002-dodge-vac-turbo-mount-5348
When I was needing to upgrade the HX35 I had one option then if I wanted to keep the brake. City Diesel's Dodgezilla hybrid.
Wasn't exactly sold on that at the time. This was 2007.
Now with the advancements in hybrid HX35 chargers and tuning there really is no reason you can't have the exhaust mounted brake...within certain limits.
I will be getting another one for this truck. When I got rid of it I missed it a lot.
Edited by Ben
I too am wanting an exhaust brake. I noticed the PRXB Is powered with an air tank. The others are powered by what? Exhaust pressure? Am I correct in thinking that there is a difference between a JAcobs Brake and a exhaust brake for our trucks?
My Banks, as many others, operates off of the vacuum system on the truck. For the most of them they close a butterfly valve in the exhaust turning the engine into an air compressor.
 The Jake brake does something the valve train. Someone else would have to explain that due to my lack of knowledge.
This is part of the reason I ended up having my Turbo built, I now have Best of Both Worlds, to a point. Still able to use my bolt on exhaust brake and 62/68/12 it's pretty decent size for what I'm doing, so far I'm happy with the set-up.
Here is a true Jake Brake by Thunder Brake.
Interesting. One off vapor ware. Saw their videos but no explanation of concept just wanting funding.
Edited by Ben
The vehicle never really slows down. Just sounds neat.
My BD brake would swing the rear end out on me in gravel given the right conditions.
AAre you happy with your BD brake?
Absolutely fantastic for warming the vehicle up vs just high idle. Although high idle + exhaust brake will open the thermostat. I found that out on a -40 morning.
I never had to replace brake pads from 2003 to 2007.
When downshifting with a load on you just felt the entire vehicle slow down. Be it snowmobile trailer, 38 foot enclosed loaded with sleds, or gooseneck with a skidsteer and mini hoe on deck.
It saved my butt a few times also.
