Tapping VP with 70k?
- Replies 22
- Views 4k
notlimah 6 posts
trreed 6 posts
Mopar1973Man 5 posts
Dieselfuture 2 posts
Popular Days
Mostly I'm just on level 3... But when the truck can break the tires loose at 70 mph, that's pretty cool..
Geez... That low in life being I had 243k on my last pump. Now replaced it with a DAP unit (Midwest Fuel Injection). I ran a full year untapped and put on over 49k miles already. Figure spring time I'
That's how my truck was run (minus the tuner) for 97k until I got it, and then I ran it with a smarty, in-tank pump, and no two stroke before I knew anything. I tapped my pump at 127k, and **** my pa
So I’m running through the pros and cons of tapping my VP. My main thinking is it’d be fun to have until I can throw bigger injectors in the truck and use the quad to tune accordingly.
My main concerns are I’m not entirely sure of the mileage on the VP. I think it’s at around 70ish and even though the PO kept good care of the truck, he didn’t have records of it and I had to call the dealership to confirm and they were a little unsure of the date as it’d been a while and they’re system had crashed at some point making certain things not show.
Either way, PO didn’t use two stroke, ran a hyper tech tuner and had an intake lift pump so I’m sure it ran under pressured and without proper lubrication until I got it.
So am I basically rolling the dice by tapping it? Or am I at just as much risk as I am now running untapped?
