Fuel in oil after injector install
- Replies 13
- Views 3.1k
Dieselfuture 4 posts
fogged306 4 posts
Mopar1973Man 2 posts
notlimah 2 posts
Popular Days
Lope could be caused from valve lash too. I had that problem and found I was bit sloppy about my adjustment and ended up being slightly too tight and it will create the same lopey idle. I
That would more likely be the Big O ring on the injector itself
Or crossover tubes not being seated correctly yea? Someone back me up but from I’ve read you gotta seat the injector, then the crossover tube, then the hold down.
I swapped my stock injectors for a set of DAP 7x.013's last week. Checked the oil level before I started it up for the first time and it was midway between the lines on the dipstick. I ran the truck for a day and checked the oil again and it was about 3/8" above the top line. So I'm definitely getting fuel in the oil. I pulled the valve cover and ran it and saw nothing. It was a bit tough to get down to each injector and inspect closely because of the fan blowing in my eyes, but from out of the fan wash area, I couldn't see a thing leaking. I never had fuel in the oil before this, so it was definitely something related to the injector swap. Bad injector? Do I need to get closer and inspect each injector while its running, or would a fuel leak be noticeable right away?
