how do I identify my stock turbo?
I recently removed my stock turbo for a SXE and have a friend that is looking for a HX35, so he asked me if my old turbo was an HX35 and I have no clue. Anybody know how or where I can locate that info? Or anybody know what should have been on the truck stock?
HX35W will be divided exhaust housing where the HY35W is a single port. Take notice tot the exhaust housing the 9cm2 has a raised rib on the HY35W. The HX35W is a smooth faced exhaust housing which is typically 12cm2 .
Image result for hx35 and hy35
HX35W has a hose between the wastegate motor and the discharge. The HY35W has a hard steel tube.
'95-'00 automatic and manual trucks had the HX35W.
'01-'02 Manual (5 and 6 speed) trucks had the same turbo. (HX35W)
'01-'02 Automatic trucks got the HY35 for whatever reason.
Somewhere along '99-'00, the HX35's went from a 6 blade compressor wheel to a 7 blade wheel.
  • Thanks 2
Autos got a HY35 to compensate for torque converter slip.  It's an emissions thing.  Quicker spooling turbo = fewer emissions right at takeoff.
94-98 trucks had an 8 blade HX.  98.5-02 trucks (both HX and HY models) had a 7 blade compressor wheel.  7 blade models flow more air, despite the compressor wheel being 2 mm smaller.
Edited by trreed
