On 4/29/2018 at 4:00 PM, Ben said:
  • ETH injectors (3946306) flow 600cc at 100bars for 30 seconds
  • ETC injectors (3944828) flow 640cc at the same test.
SO vs HO injector nozzle if I remember right there is a very small nozzle size difference. Less than 1 thousandths of a inch between the two. Again nothing to jump up and down about.
Tidbit. HotRod VP44 is the fact of mixing SO and HO pump parts tougher. Your totally gains is +21 HP typically and that HO advanced timing and like I will no advise using a tuner with timing against Hot Rod pumps. I've ran across on case where in the dead of winter it was creating a no start issue because of the excessive timing. (Hot Rod Pump plus tuner).
On 5/1/2018 at 2:34 PM, Marcus2000monster said:
Decided to wait for now. I think the oil might actually be from the old s&b oiled filter.
Have you tried cleaning it?
