- Replies 33
- Views 10.3k
Mopar1973Man 6 posts
dripley 6 posts
Marcus2000monster 6 posts
JDHudsn 4 posts
@dripley There's a company out of Texas, Super Stick Transmissions, who specialize in quick shifting NV5600's, and warranty their stock rebuilds to 700 hp. Just food for thought.
I had him rebuild my NV4500, Put in an upgraded 1 3/8" input shaft and a fully splined output shaft to fix 5th gear. Trans got stuck in 5th gear twice a few days after I put it in, he told me if
If you have driven larger truck with Eaton fuller you find out there do not have syncros at all. So it a float shift you do in those trucks. Its a matter of letting the tension off the gear matching R
Alright guys how many of you know how to float your gears in your 5 or 6 speed cummins?
Recently I tried it for the first time and it’s surprisingly easy to do no grinding and no resistance when shifting. I also tried it in my Jeep Wrangler with lil trouble.
I’ve found quite a few older posts regarding the syncros suffering from floating gears but is that only because people aren’t doing it right?
The reason being is that my stock clutch is slipping. And I’m trying to buy as much time as possible.
Any advice or personal experience would be greatly appreciated!!!
