Welcome To Mopar1973Man.Com LLC
We are privately owned, with access to a professional Diesel Mechanic, who can provide additional support for Dodge Ram Cummins Diesel vehicles. Many detailed information is FREE and available to read. However, in order to interact directly with our Diesel Mechanic, Michael, by phone, via zoom, or as the web-based option, Subscription Plans are offered that will enable these and other features.  Go to the Subscription Page and Select a desired plan. At any time you wish to cancel the Subscription, click Subscription Page, select the 'Cancel' button, and it will be canceled. For your convenience, all subscriptions are on auto-renewal.
Just changed my fuel filter, it was black, can't remember the last time I changed it. Fuel pressure was dropping with acceleration and boost wouldn't go much above 25psi, which it shouldn't with the fuel boss. Black granulars in the stock filter housing. Truck sits all winter and doesn't get used a whole lot in the summer, so I'm guessing there's algae. Anyone experience this? What's the best product to run? Bio Kleen? I'm going to change the filter again in a week or so and see what it looks like.
Edited by CTcummins24V
  • Replies 30
  • Views 4.5k
  • I have had algae in a couple of tractors on the farm, used bio kleen or whatever power service calls theirs. When I had it in the tractors it looked like black snot in the fuel filters, I got a bunch
  • CTcummins24V
    CTcummins24V
    Thank you @01cummins4ever!!! I took the bypass check valve off, no visible debris. Used a pick to compress the spring multiple times, blasted it with brake clean from both sides, compressed the spring
I've had this20180612_203951.jpg.79b36486b8b8cf988136beeaf091bda7.jpg for few years but never had the need to use it, local CAT service guy gave it to me. They use it in stand by generators that sit with fuel.
I have seen that color in mine before but no black granules with it. Any improvement with the new filter?
I have had algae in a couple of tractors on the farm, used bio kleen or whatever power service calls theirs. When I had it in the tractors it looked like black snot in the fuel filters, I got a bunch of it out of the Case that had a sediment bulb before the fuel filters and it was literally black slime that came out. Had to treat the diesel per instructions on bottle, fill tank as full as I could I let it sit for a weekend. Had to stock up on more filters, took a couple of weeks to get all the junk out after the fact.
I use it during winter every so often and try to keep tank full.  Only because of a new hire that his old job was cleaning out fuel tanks on large ships and commercial fishing boats.  His pic's convinced me just to be safe...use some. Matter of fact I'm stuck at home and fuel in my tank is 2 years old now.   I do the "shock" treatment.  I have very mild winters but lots of humidity so mold grows.
Don't store bottle under seat...type i have stinks if cap wiggles loose.  I never had a problem and hope I never do.
Edited by 015point9
Info
That's one thing for sure I can say I've never had an issue with. All these years my fuel tank still looks factory fresh inside.
Op states "black granulars"  caught in filter.  I dont ever recall seeing that in mine.  But I do change my filters probably way to often.
Ok, so I have a question here. Let's say my fuel doesn't sit too long in a tank and gets freshened up frequently, my psi stays consistent at 17-18 do I still need to change filters every so often so algae doesn't grow.
Signature says you have a fass.  I would follow their guidelines.  I buy fuel from a place that goes through lots of fuel.  So the fuel I am buying should be fresh.  When I drain my water fuel seperator I  catch it in a glass jar and look for stuff.  Ususlly 2 or 3 very small drops of what i think is water droplets.  Just me...but that's what I do, but no expert.
I have never had an issue with. Mine gets driven almost every day of the year and right now I am going thru 2 tanks a week. Even closer to home I run a tank a week usually. Never sure on the fuel I run since 5% and less bio is not marked on the pump. I do run some 5% to 20% bio blend on occasions and have for several years with no issue in the filters. My filter has looked black like @CTcummins24V's picture in the past, just no strange crud in it. I change the filter of I see a change in the fuel pressure. I don't have a set service interval.
 Thru all of that I have fuel. Last time i looked in the tank clean as new. No crud. That was how ever well 200k ago.
Truck has been garaged or not driven every winter for the past 3-4 years. I don’t think I’ve changed the filter in 2-3 years because I don’t put many miles on it...lesson learned.
Only driven once since filter change, and no pinging and panging noise from my truck. Very interesting. I’ve been thinking it was my torque converter this whole time. Maybe it was injector or vp44 noise from inadequate fuel, only in 3rd and 4th lockup.
(Side note algae and mold and vehicle not getting used much)
My air filter plunger thing never went down.  Always said it was ok.  Probably 4 or 5 years since I looked at it the filter itself.  In corners of air box under the filter I had a little bit of mold growing.  Now every other oil change i get new air filter.
Diffs...had a 87 ford that was parked for several years.  Hooked up trailer on vacation one year and diff made crunching noise.  Pulled cover and slight rust on gear teeth that were exposed to air over those years.  Not much rust but enough.  I changed out fluid and removed rust using emery paper.  Now I try once a month start and move everything I have with a cylinder in it.  Including my nail guns and generator.
NAPA had crc biocon, after 2 bottles and 1 night sitting, I now have 0 fuel pressure after a 15 minute drive. Fuel filter was spotless, so I can assume the sending unit screen is clogged?
Sorry to read your problems.
Wonder if your "black granules" are something else?
What kind of lift pump do you have?
Edited by dripley
GDP fuel boss mechanical with isspro ev1 mechanical gauge, fuel boss belt and cogs etc are fine. Pressures have been fluctuating like crazy. Normal driving 16-18psi, letting off the throttle easy it stays. Hard acceleration and the fuel pressure starts dropping, trucks sputters, and then the fuel pressure would drop like crazy, sometimes to 0. Sometimes it would recover, sometimes not. I just checked the fuel filter fine, truck was idling and fuel pressure said 0...I have a fuel tank of fuel and I really don't want to drop this tank.
What's the best way to drain a full tank? Could someone post a link?
Do you have an electrical back up fuel pump with that Fuel Boss.   If so you could add a fuel line to the system, energize the pump and have it fill 5 gallon fuel cans or stick a hose in to the tank filler neck and siphon it out.
Ibmoble way sounds Better than what i did... i just bought a new metal trash can, washed it out.  Turned upside down couple couple days to be completely dry.  Then  a cheap harbor freight hand pump... that's takes awhile.
@CTcummins24V have you checked and cleaned the by pass valve ? It could have got debris in it making it not able to close all the way
Do you have an in line strainer, pre-lift pump that could be clogged
Good call! I’ll take apart the valve and check for debris first.
Genos goodies came in today. Adding a fleetguard strainer pre fuel boss after this.
Did This Forum Post Help You?
Show the author some love by liking their post!
