Miss at idle
I wonder if they took it upart at customs to see if anything is hidden inside :think:
They ran great in my truck that's what's wired, they have about 6k on them. I would of never sold them if I knew there was something wrong with them. My apologies and hope it's something simple.
You can take it apart and see if there is any dirt in there, just make sure you put shims back the way they come out. Torque is around 32ft/lb
  • Haha 1
A small scratch or nick can cause that too, look everything over very good. I even took some 1500 and then 2000 sand paper to my injection lines before, to make them mate better, po of my truck must of overtightened them to much and I had tiny burs where the line meets cross over tube. But in your case if you moved injectors and miss moved with it then it does sound like an injector issue. I would almost pull it apart and make sure there is nothing on the end of the niddel where it seats in nozel and look inside the nozel. Use carb clean and air to blow back through tiny holes and then you can use diesel fuel to assemble.
I may strip it again next week i suspect injector too as that is all i moved and fault followed hopefully it will fix itself ?? i can get that injector out without stripping anything really now so i will take it out and clean it at some point
 tthis is my truck
I have found that in more then one case the blue lock bars that go to the isolator bolts need to be loosened as well.
Here's my tightening sequence and I've not had anything off when I follow it.
1. Head side of the lines where they go into the crossover tubes.
2. VP side of lines
3. Injector top brackets (that hold the injectors down.
4 blue lock bars
5. Intake plenum bolts
More often then not those blue lock bars and the intake bolts that they go to will not sit in the same position. And you can get a miss from not adjusting then after you turn the lines down. Everyone need to be snug.
