Advice of purchasing a Quadzilla
015point9
Can I install quad and run at “stock” levels?
If I can run at stock power levels... the valet power level used as theft protection and the turbo cool off setting will come in handy ( I think it has turbo cool down). And the MPG tune shouldn't put any stress either I would assume, but could be wrong.  Then after getting trans rebuilt and with a towing tune,  it should help somewhat pulling 9,000 pound trailer on hills.
Thanks,  your thoughts
33 minutes ago, Marcus2000monster said:
Can you have a stock fuel curve tune with advanced timing for mpg?
Yes. Like I said just set the fuel map for 100% across the board and your stock fuel rate. Then set the timing for what you want. Again you just want to inch up the timing just enough to reduce the engine load. MPG tune on stock fuel...
