Changing levels doesn't have effect
Jake7287
Did that it does have 12v
I did read somewhere if a quad is unhooked for a long time they can get a little glitchy, when I first got it the backlight and half the features didn’t work and would freeze the unit up, using info from this site I updated/flashed the display it self and everything works now, just wondering if the main box may need the same....
Edited by Steve31
Wonder if something else had happen to it then.... maybe a bad jumpstart or alt surge?
I can mat it and start leveling it up and it’s very suttle if any change at all, may just order a stealth plate, ensure a good connection and get the rigged up look outa there
