- Replies 10
- Views 5.8k
Mopar1973Man 2 posts
IBMobile 1 post
JAG1 1 post
piñon&juniper 1 post
Popular Days
This might help.
Then you would freak out to the thought I've been using "creek water" and "well water" for 16 years and the cooling system is perfect condition. I've NEVER used distilled water ever in my cooling syst
I always use distilled water. Our county water has a high level of chlorine added. (kinda messes up the avoid chlorides part) and our well water has a lot of sulphur (messes up the avoid sulfates pa
Ok- I'm about to embark on an oil cooler gasket replacement. Has anyone done it? Any tips? My search of the site has not given me any guidance, so I'll post whatever I learn in the process. if you know of any resources, please let me know.
My oil cooler leaks coolant intermittently, mostly not at all bust occasionally a lot, enough to require a gallon or more of new fluid in a day or two.
I found the cummins parts for $35 on ebay.
I'd welcome any input...
