ADR V2 Staging Flash - Race Only
View File
This base flash allows you to leave the line at a predefined Boost level.
How it works,
if mph is = 0 and you have "boost defueling" set the truck will limit fueling up to the boost defuel setting until mph > 0 then it will allow for full fueling.
Example, if you want to leave the line at 10 psi of boost, you would set your boost defuel to 9 or 10 psi ( allow for some overhead).  ensure your boost defuel is enabled.
1. Brake stand the truck and the quadzilla will only allow enough fuel for 10 psi of boost
2. lift off the brakes
3. as soon as mph > 0 then the quadzilla will allow full fuel.
4......
5.  profit
  • Replies 7
  • Views 3.7k
  • who am I to tell them they can't attempt to burn up their clutch?
  • so like 5 seconds ago I didn't want to do this, but for some reason that's changing...
Maybe this will make my tires spin, now just need a line lock for front brakes :stirthepot:
Need to specify built automatics only. I don't see being able to do this with 5 speed handshaker.
so like 5 seconds ago I didn't want to do this, but for some reason that's changing... :evilgrin:
  • 1 year later...
Probably a dumb question but can this be added to a 4k box? I tried adding it and it removed the 4k feature code. I haven't tried it on the truck yet because my truck is currently down getting a new cylinder head due to popping the gasket a few times now and every exhaust seat being very cracked.
@Me78569 could you make this for the 4k series for the gent?
I dont have the ide installed anymore to edit the base code.
