- Replies 18
- Views 7k
AH64ID 5 posts
Dieselfuture 5 posts
Mopar1973Man 2 posts
Ed ke6bnl 1 post
Popular Days
https://www.discounttire.com/learn/tire-size-calculator?cid=_kenshoo_clickid_&gclid=EAIaIQobChMIiOO93uib3wIViYKzCh1XfQmYEAAYASAAEgI3dPD_Bw That is a drastic change in size. I am thinking
They will definitely rub on upper control arms when turning, I had 295 when bought the truck and they rubbed a little on full lock. 285 did not but we're close.
I have hummer tires and wheel that I believe are the same size. No rubbing and have a 2 in. Simple lift on the front
I apologize if this has been answered before, but I couldn’t find it, and I have to make a quick descision. I have an opportunity to buy a set of 17” wheels from a 2003. They have 315-70-17 BFG KO2’s on them. I am stock ride height. Any issues with rubbing or handling? I know they will be heavier, and will mess with final drive ratio. As far as fit, is there anything I am missing? Not sure if there were offset differences.
