A/C blower conversion
Stanley, you are a bad mofo! That saved me some time! I can calculate that all out if you can drop a tape measure or a known object into the pic. Can you also get me a height dimension of the lip on the bottom of the box, and maybe the height of the squirrel cage?  Thanks a million.
If you do the Heater Treater blender door upgrade, do not press it all together too tight. If the blender door sits too low it will hang up in the box. Its hell getting it separated once the box is in.
Google heater treater and you will see. It replaces a plastic part on the blend door with a metal one and you reindex the motor that drives the door. The plastic part cracks or brakes and throws the door out of whack.
Edited by dripley
Since you have the hvac apart it is a worthwhile thing to add. It is very esy to install while box is out. Much more difficult to do with the box installed. The space is very limited. The part is pricey for what it is but I replaced mine while I had the box out for cheap insurance.
Edited by dripley
Thats the part. It was only $25 when I bought mine. Even pricier now. But I will say if the plastic breaks later the 35 bucks will look more reasonalble. At least thaT is how I looked at it at the time. I hate laying in the floor board with 2/3 of me hanging out of the cab.
