2001 auto, Rattle near steering column
My truck has a rattle near or in the steering column. I thought this will be easy. Removed most of the plastic on that side. Expected to find a wire bundle rattling on the plastic. Had it apart twice. Any ideas. I know this is a stretch.
3 minutes ago, Nekkedbob said:
Both of my 2nd gens had a rattle in the columns that turned out to be the bottom bushing. Open the hood and check the steering shaft for side to side play. There is a fix but I cant remember what it is called. Maybe some one can chime in.
I have seen a Delrin Bushing Kit replacement for the "Bearing" that is installed at the lower end of the steering gear.  There is a clip ring a preload spring.  I saw the fix on You Tube?
Michael
