Power steering fluid leak?
2 hours ago, portlandareae28 said:
It has the correct fluid in it, seems like for it to be able to drop right straight down to the driveway that it may be the steering box leaking.
My hydro boost was leaking PS fluid and going to ground.
2 hours ago, Marcus2000monster said:
They like to leak from the seal between the ps and vac pump. Might check they’re.
That would be oil though, correct?  It definitely wasn't oil on the driveway yesterday.
I have been noticing more oil drips from my Moparman ccv mod though, anyone run a catch can on these?
20 minutes ago, Mopar1973Man said:
Let it drip. Catch can just make a bigger mess. When it fills up and sloshes around. Never worked in the front of the engine why would it work on the back of the engine. Still a broken idea.
I don't like it all over my driveway, so hoping for a solution, I would rather drain and clean a catch can every couple months, than scrub my driveway all the time.
Go over to Home Depot and pick up there industrial degreaser. It's super strong and does a excellent job of getting the grease off the truck. I typically mix it up in a small garden sprayer and hose the entire front of the truck down. Engine, suspension, frame, and underside. Then power wash it all off.
https://www.homedepot.com/p/ZEP-1-Gallon-Industrial-Purple-Degreaser-ZU0856128/100047759
https://www.homedepot.com/p/Chapin-1-Gal-Lawn-and-Garden-and-Home-Project-Sprayer-20000/304862343
Thank you, might have to do it twice :-)
Mike, do you put it on full strength or dilute?
