- Replies 12
- Views 2.3k
Dieselfuture 3 posts
IBMobile 2 posts
Bullet 2 posts
Octafish 1 post
280 ft-lbs
If you go under spec, you don't pre-load the bearings correctly. And tapered roller bearings usually use barrel shaped rollers in the races, so it's important to correctly preload the bearing so the
I'm replacing the wheel hubs/bearings on my 2001 2wd 2500.
What are the torque specs for the big nut?
Thanks!
