Quadzilla Help!! No Boost or Power
CBond
On 4/21/2019 at 9:56 PM, BrokeAssPainter said:
Hey guys, I'm just switched from hy35 to hx35 and I can't seem to build more than 14 lbs of boost according to the iquad, analog boost gauge says more around 16 or 17 but I had no problem getting 21psi from my hy35.... Anyone else have this kind of issue?
i just put a plug in the turbo housing and rely on tuning or defuel settings if all else fails. I don't like the boost elbow, I may do a turn buckle some day. At this point I really have no use of the waste gate. Just use common since when plugging it off.
  • 3 months later...
On 4/15/2019 at 7:32 AM, Mopar1973Man said:
You didn't do the P0237 testing, did you? This is not a Quadzilla fault but a wiring fault.
On 4/15/2019 at 7:28 AM, Me78569 said:
Did you buy the quadzilla new?
when you clear codes and drive around do you get any codes that come back?
Are you %100 sure you plugged the map wiring in correctly?
Never updated this thread but I sent my unit back to Quadzilla and they sent me a new unit.  Ended being something wrong with the boost circuit.  Works like a charm now.  Sorry for all the trouble! Gotta figure out these custom tunes now. :D
