- Replies 16
- Views 7.8k
LorenS 8 posts
Mopar1973Man 3 posts
Me78569 2 posts
Dieselfuture 1 post
read live data from your IAT and ECT sensors. are they accurate? If the IAT got damaged and read low temps it would cause high idle.
I can't picture the screw you are talking about, but one possibility can you replace it with a longer screw and use a jam nut to help hold it? another option is to "disturb" the threads a bit. Use a
Could your TV cable somehow be causing issues with your throttle linkage? Maybe something is hung up there, if the TV is not set correctly you will have some other issues for sure in general. Just loo
Friday I serviced the transmission, including taking out the valve body to replace plastic accumulator piston with metal one, (manual valve?) to allow flow to torque converter while in Park. I have noticed the last couple of days that the truck - even when warm after 30 mile drive - idles higher than normal, around 1250 versus 800ish RPM. This is in park or neutral. The tach isn't wonky, I only looked at the tach because it sounded fast. Idle while in drive seems normal. I have checked the transmission fluid after 30 mile drive home on interstate, truck in neutral on level ground and it's in the middle of the hatch mark, same as the last 30k miles. Fluid is not "foamy".
Anyone have any ideas on what may cause this? No other symptoms or driveability issues. Fuel pressure same as always, engine temp the same, EGTs run the same, voltmeter reads the same, even the MPG estimator seems normal. I'm befuddled! Had over 200 miles on the tank of fuel before symptoms showed up.
