- Replies 16
- Views 6k
Fumminsman 6 posts
Evan 4 posts
Timd32 2 posts
Royal Squire 1 post
Well it ended being the transducer in the transmission even though it was already new
Hello I’ve read many posts on here and solved many problems on various trucks from articles I’ve read here so I believe y’all can hopefully help me here. I have an 03 ram 3500 5.9 with a 48re. I bought this truck with a bad transmission so I had it rebuilt. I installed it and now I’m having shifting issues. If I start the truck and the first time I put it in drive it starts in first and drives fine but after that it won’t downshift below 3rd. It will easily downshift manually into 2nd but will only manually shift into 1st if I shift it prior to stopping and then it will shift in just before the truck stops. The truck is completely stock I have a smarty touch but only use for monitoring the engine. I’m at my wits end I need help to figure this out. Thanks
