1999 24 valve high idle and bucking at highway speeds
- Replies 31
- Views 6.7k
24vgarrett 15 posts
Mopar1973Man 6 posts
IBMobile 2 posts
kzimmer 2 posts
Didn't say Jack about setting any voltage on Timbo. The phrase "There is no voltage to check" could lead people astray. If your not checking voltage, why do you need a voltmeter? So do
It sounds to me that you are describing the normal cycling operation of the intake manifold heaters . Combined, the two intake manifold heaters draw about 200 amps - that is why your are seeing the d
So I have a 1999 24 valve all stock no tuner.. and I can start the truck and it fired right up and it will idle around 800 or so rpm and when I hit the throttle it will idle at 1100 and at highway speeds the truck will buck and if I let off it’s fine until I get on the throttle again I just replaced tps/apps and set the correct voltage and done the pedal thing the map and iat sensor are showing they work on my scan tool but no codes I’ve only owned the truck for a couple weeks and the vp44 has a sticker on it and it looks brand new all my ground are good but idk what to do.....
