Recommendations
Ram 2500 2wd I really don’t do a lot of towing atm
Right now I have dap 100hp injectors my quadzilla is on it’s way back with v2 update and I got a buddy that’s local that has a new hx40 on the shelf that he said he could swap exhaust housings on for me for $500
my question is do I need to go with head studs
Edited by Steve31
  • Replies 53
  • Views 9.2k
  • Mopar1973Man
    I want to do the 62/68/12 so bad yet... Current the HX325/40 I'm running is 60/60/12 which is close to HE351 turbo from a 3rd gen.
  • Mopar1973Man
    3 years ago... But worth every penny.
  • Dieselfuture
    Dieselfuture
    They sure do, I was just giving you crap.
If your intention is the run it hard then yes.
Not really, it’s more of a daily just want it to have spunk to wax out a Chevy once in awhile lol
I would spend the money on studs and skip xh40, save more and get something like 62/68/12 or 14 s362 I believe. For now guessing you have xh35,?, 100hp injectors and qwadzila will be pretty fun too.
If someone didn't blow all the money on lights:whistle2:
The guy told he built a turbo for his buddy it was something like an hx40 with a banks exhaust housing for a 12v that was just nasty
and spooled super fast,
so is a 35/40 turbo not worth the money?
i was just looking to get a reliable 30ish psi
didnt want to push the ole 300k mike goat to hard ?
62 65 14 with 7x009 without studs plus smarty.
Truck not driven hard and does tow.
62 65 14 is roughly the same s 62 68 12.
Glad I went this route over the hx40. I'm in the s300 with 3rd gen forward facing housing about 700 bucks with stainless diesel intake tube and boots.
My turbo install was a goat rope because I accidentally ordered the 3rd gen style with 4.4" exhaust outlet.  I also fabbed  4.4 down pipe.
Nothing about my set was a bolt on affair for my 2nd gen. But somehow worked
This set up spools extremely well. Compared even to how the hy35 spools and makes numbers well over 30psi with no egt issues even pulling 18k
Edited by Evan
If I’m understanding right, no studs your pretty much limited to 30ish psi
what kinda timing? 22-25* to keep the gasket from playing peek a boo
Actually stock can handle quite a bit. I was upwards of 25 and 27 degrees of timing yet. It between the boost pressure and the timing. Figure the boost pressure 30 PSI being compressed is 1,100 PSI in the cylinder. Then add lots of timing that is enough to spike cylinder pressures. But timing is based on nozzle size, pop pressure, and a few other factors like cetane... So the timing number will vary because of the other factors.
I've seen 40psi without making the head gasket blowout.
But thts upper rpm pulling grades normal driving I rarely even see 30
Same I was making 45 PSI and still holding the gasket too. My gasket failure was rear passenger side coolant jacket. I'm going to say I over extended my coolant change a few times.
I'll disagree and say it happened of old age. Seems a lot of hg failures lately. All trucks are getting old. Jmo
Ok I can tell you I was there when my injectors where assembled pop pressure is spot on at stock guide lines with dap 100hp nozzles
Right from the FSM.
So stock is 310 bar. The bottom end is 293 bar. Within about 20k to 40k miles you can lose up to 10 bar with everything settling. Few member here have seen this.
Range of use is...
  • Lower limit is 4,250 PSI which is equal to 293 bar.
  • STOCK - 4,500 PSI which is equal to 310 bar.
  • Upper limit is 4,750 PSI which is equal to 327 bar.
Like my 7 x 0.010 were popped at 320 bar (+10 bar over stock). This gave a good bump in MPG and reduced smoke. Some will argue that increasing pop reduces flow some. Then it also affects timing as well making it retarded you can make that up on a Quadzilla though.
Another way to check pop pressure...
This method does work and found several truck with zero engine load and idle RPM above 800 RPM's. This is because the injector is opening too early and flowing too much fuel. The ECM and VP44 can't defuel any more. Hence the pop pressure is most likely below 280 bar at this point.
Mine were set at 310bar ...all 6 the guy was real picky and wanted the exact number on all 6
my quad should be back home today I’ll hook up the laptop and check the above and post it
Edited by Steve31
Ask @pepsi71ocean he got a set of DAP injectors 100 HP. Ran them about 28k miles and they had dropped to 280 to 290 bar IIRC. So just because they were set perfect at 310 bar they will still settle in after a break in period typically lose about 10 bar at the worse case.
Another way... My 7 x 0.010 injectors were popped at 320 bar. My engine idle was a perfect 800 RPM but the engine load was higher at 13% when the injectors are new. I've got roughly 60k miles on these injectors at just about a year old or so. Now the engine load has dropped to 6% at idle. Idle speed is still correct but the engine load is dropping out and eventually the injectors will be below minimum pop. I figure right at 100k miles these will be wiped out.
My stock injectors had 150k miles on them. I had them sent in to be popped and rebuilt. Fun was the stock injectors idled high at 850 to 875 RPM. Didn't have a Quad then... But the pop pressure was 260 bar. I bet for sure engine load was a ZERO.
