- Replies 25
- Views 4.7k
dripley 9 posts
JAG1 5 posts
Mopar1973Man 4 posts
Ironforger 3 posts
Ok guys got my vacuum pump resealed, no more oil being pushed out the CCV, and got my vacuum lines replace so my heater works on all positions. Fixed the banjo bolt leak on the back of the head, and T fitting leak on the return line. But I still have a bad problem until the truck is fully warm it has no power still, and if the outside temp is below 40 it loses power bad. And still have a hard starting issue has to crank for around 20 seconds and then until it sets for about 3 hours itll stat back instantly. New batteries, cranks fast, new fuel filters, fass DRRP lift pump. 15psi fuel pressure idle, 9 WOT. Any ideas would help I'm thinking my VP44 is shitting the bed it's never been replaced.
